429/460 HEI Distributors - 460 Ford Forum
Go Back   460 Ford Forum > Classifieds > Vendor (FOR SALE)
Vendor (FOR SALE) This section is dedicated to all vendors who wish to place ads for their new products.
Old 01-10-2013, 03:36 PM
CarsByCarl's Avatar
CarsByCarl CarsByCarl is offline
CarsByCarl Driving a Ford
Default 429/460 HEI Distributors
$99.95 for one
$149.95
for two
-Easy one wire hook-up
-Completely self contained. No need for an ignition box or external coil
-Mechanical advance pre-curved for performance use, and easily adjustable with commonly available spring kits
-Adjustable vac advance
-Double pinned drive gear
-Supports up to 7,000 RPM
-Black cap and coil
-This is the same HEI distributor Summ...other retailers sell for $139.95. Same box, same instruction sheet, same part.
-This is also the same distributor Carl runs in his own car. Field tested by driving 375 miles to a race, running 120+mph for extended periods in the race, and driving 375 miles home in 100+ degree temps.
High quality brass terminals and a protective plastic dust cover that encapsulates the 65,000-volt coil. A new cast-aluminum housing featuring a machine polished finish contains new bushings, mainshaft assembly, and a hardened steel gear. Our HEI includes high-output module, centrifugal advance components, and adjustable vacuum advance canister.
Your one stop shop for BBF engines and parts
Master dealer for Lunati, Diamond, Probe
Warehouse distributor most other speed parts
Old 05-01-2013, 11:00 AM
CarsByCarl's Avatar
Four month bump.
Old 06-01-2013, 10:10 AM
snotrocket snotrocket is online now
snotrocket First On Race Day
Carl I just wanted to say I got my parts today, and it was great dealing with you would do it again in a heart beat. Bump for a good deal and a great guy.
Ps. Thanks for the shirt it was a pleasant surprise I bet I'm the only guy in Victoria to have one lol. 😎
Sent from AutoGuide.com Free App
Old 06-03-2013, 11:48 AM
CarsByCarl's Avatar
Thanks for the order Tristan.
Old 07-11-2013, 10:48 AM
xoliex xoliex is offline
xoliex First On Race Day
what kind of advance can these be configured to?
Old 07-11-2013, 04:16 PM
CarsByCarl's Avatar
There are several companies that sell advance curve kits for HEI distributors, and they're usually available at your local Autozone, O'Reilly's, etc. for about $5.00. They come with a chart that shows different advance curves and amounts of advance for various combinations of springs.
Advance kit instructions: http://www.moroso.com/catalog/images/72300_inst.pdf
Old 08-22-2013, 05:55 PM
these look like good dizzys and it doesn't need a external module box like a MSD. but how would you add something to this like say a 2 step rev limiter, max rpm limiter, and possibly a timing retard?
Old 08-22-2013, 06:27 PM
CarsByCarl's Avatar
Rev limiters and other add-ons are available from MSD and other manufacturers. We can supply those with this distributor if desired.
PM/email/call for details.
Old 03-20-2014, 09:53 AM
CarsByCarl's Avatar
Back in stock, just in time for that spring tune-up!
Buy one, get the second at half price. Once you install one of these, you'll want to run them on all your 460's.
Old 05-16-2014, 06:53 PM
Lem Evans Lem Evans is offline
Lem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue Path
bump
B F Evans Race Parts
270-278-2376
Old 05-18-2014, 08:08 AM
Former429's Avatar
Former429 Former429 is offline
Former429 First On Race Day
Carl, can that gear be used with a solid roller cam?
Old 05-19-2014, 10:37 AM
CarsByCarl's Avatar
The gear included with the distributor is for flat tappet cams.
Old 06-07-2014, 07:49 AM
73 porkchop 73 porkchop is offline
73 porkchop First On Race Day
Default advance curve kit
You mentioned earlier that a advance curve kit is commonly available. Yet a 460 ford turns counterclockwise and a standard GM turns clockwise. So wouldn't a standard HEI mechanical advance kit not work because as it spins counterclockwise its going to be locked up?????
Old 06-07-2014, 02:50 PM
CarsByCarl's Avatar
I don't know anything about how a GM engine works, but I do know the advance kits work in these distributors just fine.
Old 07-19-2014, 04:01 PM
bump
270-278-2376
