c6 trans won't go into gear. - Page 2 - 460 Ford Forum
Go Back   460 Ford Forum > Full Race Tech > Driveline
Driveline Transmission, Clutch, Gearing, etc...
  #16
Old 06-18-2013, 01:17 PM
rat poison rat poison is offline
rat poison Driving a Ford
Originally Posted by gregaust View Post
Pressure gauge is required to diagnose any further IMO.
I would try that but the trans. is already out of the car.
You want to race for cheap? Drive a chev. If you want to win? Drive a FORD!
Old 06-27-2013, 05:57 PM
Well this is what I found when I pulled the trans. apart.The valve body had a lot of debris in it especially in and around the pressure relief valve.It looked like this caused the valve not to seal properly.And that burned out the intermediate and high gear clutches.That's all I could find wrong.I'm not sure where the debris came from except I didn't flush out the cooler or the converter,so I figure it must of came from one of those two places.I'm ready to put it back in the car now but not before I make sure everything is flushed out first.
  #18
Old 06-27-2013, 11:48 PM
Frank Merkl's Avatar
Frank Merkl Frank Merkl is offline
Frank Merkl Driving a Ford
The clutches burnt up first! then the debris stuck the valve in the open position
Frank
check the line pressure when you fire it up again , you need 150 psi @ 2000rpm min
  #19
Old 07-16-2013, 10:19 AM
Okay thanks Frank I'll do that.
  #20
Old 07-16-2013, 09:45 PM
stuarta stuarta is offline
stuarta Driving a Ford
You probably mean forward and direct clutches. C6 does not have intermediate clutches.
Wrench twister since 1957.
Journeyman in 1964.
Transmission builder since 1964.
  #21
Old 07-24-2013, 10:27 AM
My bad your right,anyway trans seems to be working now.We'll be racing in 2 weeks and we'll see how she stands up then.
  #22
Old 09-06-2013, 08:26 PM
The transmission is working perfectly!I got put out in the final round.The car ran 6.73 to 6.76 in the 1/8 all week end,except the final round it slowed to a 6.80.I think the trans was getting hot by then.I'm going to put in a trans.cooler with a fan for next year.And a transmission temperature gauge.Thanks for the help.
