Valve Lash Adjustment Charts - Page 2 - 460 Ford Forum
Go Back   460 Ford Forum > Tech Topics > Engine Tech Archive
Engine Tech Archive A collection of all posts from the old Network54 forum
  #16
Old 06-17-2012, 06:34 AM
quick 52 quick 52 is offline
quick 52 First On Race Day
nice info. not to be a a$$ but you have a chart for X brands. i run a ford but like all three brands and run them to.
Drag week quickest street rod
2009 2010
Old 06-21-2012, 06:55 PM
GT300TD GT300TD is offline
GT300TD Driving a Ford
Does the three position chart system work as well as the 90* chart. I used the three position system, it seems to run ok but I just want to make sure it runs the best it can. The system I used was a lot easier because I adjusted them by myself.
Thanks.
'64 Galaxie 500 XL 466/C6, '06 Mustang GT
  #18
Old 06-21-2012, 08:31 PM
D Pope's Avatar
D Pope D Pope is offline
D Pope First On Race Day
You can always get a cylinder so the valves are in the split overlap position (both valves open) and set the valves on the cylinder that's four down in the firing order.
1949 Mercury coupe
Nosed, Decked, Frenched
58 T-Bird interior
472 w/toploader 4 speed OD
Performer RPM w/Holley 3 barrel
Isky 304 degree solid cam
Narrowed 3.25 9.5 inch with Detroit Locker
  #19
Old 09-22-2013, 12:15 PM
68formalGT's Avatar
68formalGT 68formalGT is offline
68formalGT Driving a Ford
Originally Posted by Danny Cabral View Post
Excerpt from Bret Powell's post on setting valve lash with big camshafts:
Adjust the intake when the exhaust starts to open.
Adjust the exhaust when the intake is almost closed...not when it starts to close.
What happened to the 3 position chart?
Joey
  #20
Old 09-22-2013, 01:58 PM
ag460torino's Avatar
ag460torino ag460torino is offline
ag460torino Bleeding Blue
Default 3 position chart....
give me a sec and I will post a 3 position chart
  #21
Old 09-22-2013, 05:00 PM
68formalGT's Avatar
Thank you. It looks like you found that in a book if so what book did you find it in if you don't mind me asking?
Joey
  #22
Old 09-22-2013, 11:19 PM
Default books
that is out of "how to rebuild ford v8 engines" by Tom Monroe. The other book with good engine code info is " how to build max performance ford v8's on a budget" by George Reid
Call on me anytime if I can help......
Auggie
  #23
Old 09-23-2013, 02:41 PM
68formalGT's Avatar
Thanks again Auggie.
Joey
  #24
Old 10-07-2013, 05:56 PM
Smile 3 position method
Crankshaft at TDC on compression stroke
#1 #7 #8 Intake
#1 #4 #5 Exhaust
Rotate crankshaft clockwise 180* (half turn)
#4 #5 Intake
#2 #6 Exhaust
Rotate crankshaft clockwise 270* (3/4 turn)
#2 #3 #6 Intake
#3 #7 #8 Exhaust
  #25
Old 10-08-2013, 04:20 PM
Falcon67 Falcon67 is offline
Falcon67 Driving a Ford
I use this procedure on everything - solid or hydro. EOIC works, you don't need a chart or a firing order, just go one cylinder at a time. This is specifically directed at the questions I used to get about setting hydros but I use the same on solids and get it done.
http://raceabilene.com/kelly/hotrod/valveadj.html
Pick a cylinder.
Bump the motor until the Exhaust valve starts up. Intake is now on base circle.
Loosen the intake lock nut.
WAIT a minute or so, to let the plunger relax.
Twirl intake pushrod between thumb and forefinger (hold gently) and tighten the lock nut until you feel the pushrod stop turning. A little practice is all it takes. You will know - it stops right away, unless you are turning it with pliers. This is zero lash.
Tighten locknut 1/2~3/4 turn.
Bump the motor until the Intake is almost down. Exhaust is now on base circle.
Loosen the exhaust lock nut.
Twirl exhaust pushrod between thumb and forefinger (hold gently) , etc...
Repeat as necessary.
1967 Falcon 4 door
Owner built, owner abused.
http://raceabilene.com/misc/hisnherspic.jpg
