477 "Simple" Build - 460 Ford Forum
Go Back   460 Ford Forum > Tech Topics > Engine Build Archive
Engine Build Archive A place to archive DYNO or 1/4mile VERIFIED engine builds. Please post any engine tech questions to the Engine Tech forum.
Old 11-10-2013, 12:49 PM
Price5113 Price5113 is offline
Price5113 First On Race Day
Default 477 "Simple" Build
We just finished up the dyno session on a 477 build for a friends 78 Fairmont yesterday. Very informitive session as we ran this engine the better part of 20 or so runs, mainly trying out some different intakes. We started off with a untouched Offy T/Ram with two 650DP Holleys and then switched to a TFS Mafia intake. Bigger carbs would surely have helped but thats all we had to use. I did try out my Offy single top plenum and it was worth around 20HP more than the twin top and no loss of TRQ. My top was ran with a 1050CFM Dom. The intake was then switched over to a new 'out of the box' TFS Mafia intake, with a TFS 1" spacer, and a 1050CFM Dom and thats what this combo seemed to prefer although we had to spin the eng more RPM. The dyno sheet I posted is the most conservitive pull with the TFS intake because no stud girdle was installed. We did spin to 6900 & 7000RPM and the eng responded to the tune of 687HP. The build is as follows: D1VE block(sonic checked), early 2Y crank, PEP H beam rods, SRP 'flat top" pistons, JE rings, Oregon Cams ground flat tappet solid cam (260/266@.050 110*L/Sep) Crower Cool Face lifters, Crower .120 wall P/Rods, Crower Stainless 1.73 Rockers, Isky V/Springs, & Ti Retainers. The comp. ratio worked out to 12.2 and VP110 fuel was used. 34* of timing seemed to be what worked the best. The heads were opened to CJ size on the Int. runner and bowl blended. All in all a straight forward combo with a tick over $5K wrapped in it....................
Old 11-10-2013, 05:44 PM
460VEGA's Avatar
460VEGA 460VEGA is offline
460VEGA Driving a Ford
Smile
Stock stroke & flat cam, good #s. That Fairmont is gonna fly!!
74VEGA 466 C4 6.18@110,9.77@135.66 ON PUMP GAS
Old 11-11-2013, 07:02 AM
Default Flying Fairmont
Thanks for the compliment! I imagine the Fairmont will haul, when he gets it to 'hook' which should'nt be to tough seeing how its a Fox body..........
Old 11-11-2013, 08:22 AM
BOSS 429's Avatar
BOSS 429 BOSS 429 is online now
BOSS 429 Driving a Ford
nice build
RICH
CIRCLE (R) 815 712 8738
BUY,SELL,TRADE BIG BLOCK FORD parts
CLYINDER HEAD PORTING
COMPLETE ENGINES
STROKERS TO STOCK SCJ TO BOSS 429'S
632 557 532 598CI ETC
READY TO RUN OR DYNOED
Old 11-11-2013, 08:06 PM
Default Thanks.....
Thanks for the compliment. Im still amazed at the TRQ it made, wouldnt have thought it would have made near that amount..............
Old 11-11-2013, 09:10 PM
windsor windsor is offline
windsor Driving a Ford
Thumbs up
Old 11-12-2013, 06:49 PM
SLG SLG is offline
SLG Driving a Ford
What size headers?
"If your gonna be stupid, you gotta be tough"
Old 11-13-2013, 06:57 AM
Default 2" X 3.5"
The headers used were Hooker Fox swap peices(2"prim, 3.5" coll, not sure on the prim, tube length off the top of my head)...............
Old 11-15-2013, 01:24 AM
Devildog Devildog is offline
Devildog Driving a Ford
Send a message via Yahoo to Devildog
Nice build....similar to mine. Good results...........D
'71 Mustang Mach1 466
'09 Shelby GT500
Old 11-18-2013, 09:15 PM
Default Your build/
Hey D, what did your build consist of? thx for the compliment!
Old 11-18-2013, 09:24 PM
BOSS 429's Avatar
Those headers work very well
RICH
COMPLETE ENGINES
Old 11-23-2013, 11:04 PM
It's not together yet because I'm still working on the car. Using flattops, a Victor intake, TFS CJ heads, and 1 7/8" Hookers for now (because I have them). Using solid cam with a bit more duration and a bigger split.....Probably will end up using a Dominator and going to 2" headers. Going to try different intakes to see what is quicker in the car. Still working on the heads and have been working on a Port-o-sonic to try out against the Victor and a TFS intake like the one you are running. Then will end up running a stroker of some kind eventually like everyone else....lol.....D
'09 Shelby GT500
Old 11-24-2013, 08:58 AM
Default Intakes........
Have you done any mods to the Offy POS? The TFS Int is hard to beat for an 'out of the box' peice.........What work are you doing on the heads? Steve..........
Old 11-24-2013, 09:53 PM
On the POS I am trying to port it as much as possible and do CJ port match. Opening up the carb flange and plenum....and thinking of doing up a HVH 4500 adapter like I saw on an EMC engine years ago....Porting the heads and need to flow them and see how they are doing (until I am happy), which is never....lol. The Victor is a 4150 flange as well....not sure how I will address the flange on that one, although it is the same as a 4500 version. Just need to redrill it....might just use it like it is at first with my 4150 1050 to get it running and then go from there. The car is just giving me so much work to get back together, I have not had time to finish up all of the engine work yet........Keep us posted on your progress.....I sure like the heads you are running....D
'09 Shelby GT500
Old 02-18-2014, 11:27 PM
G-Code G-Code is offline
G-Code Driving a Ford
nice numbers, love those trq numbers
http://i201.photobucket.com/albums/a...elake3-1-1.jpg
Going fast is only half the fun....what you make go fast is the other.
