1949 Mercury coupe - Page 10 - 460 Ford Forum
Go Back   460 Ford Forum > Tech Topics > Car Buildup Forum
Car Buildup Forum A place to detail your car build and chronicle your progress as you put together your BBF powered vehicle.
  #136
Old 01-24-2014, 08:40 AM
Bigred69 Bigred69 is offline
Bigred69 First On Race Day
That looks awesome.
Old 02-07-2014, 07:36 PM
D Pope's Avatar
D Pope D Pope is offline
D Pope First On Race Day
Did I ever mention that I hate doing upholstery?
Anyway I got the back seat covered but there's still a few wrinkles to work out later.
I'm glad I went with the red and white. It's quite striking.
Now the buckets. AGGHHHH-----
1949 Mercury coupe
Nosed, Decked, Frenched
58 T-Bird interior
472 w/toploader 4 speed OD
Performer RPM w/Holley 3 barrel
Isky 304 degree solid cam
Narrowed 3.25 9.5 inch with Detroit Locker
  #138
Old 03-05-2014, 03:56 PM
D Pope's Avatar
I got the drivers bucket bottom half covered then had to do something other than upholstery.
I wanted the trunk compartment completely sealed off from the passengers compartment so I caulked all the cracks and used spray foam on the big gaps. I also filled the gap between the Merc package tray and the T-Bird tray with spray foam to stop if from vibrating with the stereo. Then I glued in a piece of automotive carpet underlay to quiet things down a bit.
Next I decided to fix the tranny hump. What I had started was quite crude so I Zip-disked it out of there and cut up an old water pressure tank that was the right size to do the job. When I get that done I'll have to trial fit the bucket to see what needs changing.
1949 Mercury coupe
58 T-Bird interior
  #139
Old 03-10-2014, 10:02 PM
D Pope's Avatar
I welded the pressure tank piece to the removable tranny hump then had to evacuate my house for a while. The tank must have used some kind of epoxy paint or the like because it really made me dizzy. I opened the house windows and went to town for a long coffee break.
Next I laid more underlay for soundproofing. The cat thinks she's got a new home.
The shifter handle had to be tweaked quite a bit but it's good now.
The wires are for the taillights and speakers. They had to be tunneled through the foam.
1949 Mercury coupe
58 T-Bird interior
  #140
Old 03-19-2014, 08:41 PM
D Pope's Avatar
The battery is going in the trunk on the drivers side so I bought 25 feet of 2-0 cable. The copper is a half inch diameter so that should overcome the distance factor.
The cables are going inside the console so I'll use some of that split wire loom for extra protection.
I have a Slug Buster tool from a farm auction so I used it to make some 1" diameter holes in the partition behind the back seat. It worked pretty slick too.
I got some solder on cable ends with the cable. I'll use a side post battery to make them work.
I also got some cable hondo clamps to use to ground the cable to the body and frame. They'll hold everything in place too.
It's going to take the full 25 feet of cable too.
1949 Mercury coupe
58 T-Bird interior
  #141
Old 03-20-2014, 10:45 AM
jeffgfg jeffgfg is online now
jeffgfg Driving a Ford
Be careful! what probably happened when welding/cutting the tank....it was probably galvanized which you should never weld on with out prepping it. I don't remember what you are supposed to do to it to make it safe. But be careful it can cause serious harm.
  #142
Old 03-20-2014, 03:20 PM
White Lightning's Avatar
White Lightning White Lightning is online now
White Lightning First On Race Day
Galvanize when heated to melting and smoking temperature releases Cyanide gas...and we all know what THAT does to us! lol Drinking huge quantity's of milk helps to counter act the effects.
Looking REAL good Pope!
Rob
Rob Hawes-Anchorage Rod Works-Anchorage, Alaska
  #143
Old 03-22-2014, 12:25 AM
D Pope's Avatar
The tank wasn't galvanized, just funny paint. I've welded galvanize but I do that outside with a good wind to keep the fumes away from me. That thick stringy greenish smoke just doesn't look healthy!
Running a couple of battery cables is a simple job.
Right!!!
It took me most of two days to get it done. I ended up clamping the ground cable to the body in three places to keep it from getting into places it shouldn't be. My brother had a Fox Mustang with the battery in the trunk. His buddy had a fat chick in the back seat and they wore through the positive cable and caught the seat on fire. I don't want that happening to the Merc!
The ground cable goes through the floor then grounds to the frame and ends bolted to the tranny tailstock.
Next the console got bolted in permanently. I'm going to put a piece of stainless on the flat part that the stick goes through and cover the rest with vinyl and carpet below the chrome strip.
1949 Mercury coupe
58 T-Bird interior
  #144
Old 03-25-2014, 10:25 PM
D Pope's Avatar
I was in Swift Current (100 miles from home) the other day and spied the Merc on the top of the scrappies pile. I climbed the 25 feet of junk and took a few pieces off. The dash and grille are still good so I'll go back when it warms up and get them. You can't have too many teeth in a grille!!
I cut a piece of stainless for the top of the console and mounted the power seat switches in it. I had to put the seats back in and try it for fit. The bucket was too high so I fixed that.
The stick is at the machinists. He has to shorten it and rethread the end so the B+M shift handle will fit.
1949 Mercury coupe
58 T-Bird interior
  #145
Old 03-26-2014, 12:39 AM
Dman64's Avatar
Dman64 Dman64 is offline
Dman64 First On Race Day
It's really coming together, lots of great scrap in that yard. Is the yellow slick picker truck yours?
I'm over in southern Alberta, let me know if you come across a 57 F100 if you don't mind.
Thanks D
Sent from AutoGuide.com App
1964 F100 466 zero decked fuelie 7cc dish pistons, with RHP 2.11 1.65 budget D3 heads, Voodoo cam 219/227, rpm intake, Holley Terminator EFI, MSD Ignition, MSD FORD TFI Distrbutor, 4R70W Trans with Baumann Re-cal kit, US Shift electronic Trans controller with B&M Megashifter, 2500 Dirty Dog Convertor, 3.50 gears with detroit locker.
http://www.flickr.com/photos/36499599@N04/
http://www.youtube.com/watch?v=rbl-v...3&feature=plcp
  #146
Old 03-31-2014, 07:37 PM
D Pope's Avatar
When our rural municipality was done with that picker truck we got it for 150 bucks. It needed a set of heads but that was nothing. Handiest thing on the farm now
I had to get creative mounting the tach in the dash. The speedo surround piece lost all its mounting lugs so I fibreglassed it in place. I was on a roll so I hose clamped a tin can around the tach then propped it at the angle I wanted. I packed Bondo between the can and the dash to fasten it in place. Now I can loosen one of the hose clamps and slide the tach out of the dash if the need arises. Just a little body putty work to pretty it up and I can paint the dash red.
1949 Mercury coupe
58 T-Bird interior
