Rollerizing a C6 - Page 2 - 460 Ford Forum
Go Back   460 Ford Forum > Tech Topics > General Tech
General Tech A place to discuss general tech regarding chassis, transmission, tires, suspension, non-460, etc
  #16
Old 01-27-2014, 01:26 PM
Fordmanmatt's Avatar
Fordmanmatt Fordmanmatt is offline
Fordmanmatt First On Race Day
Garage
Frank I went into photobucket and I typed your name in severalways to look at those picks but no luck I tried fmerkl, frankmerkl merkl, fmerkel, no luck!!!
Originally Posted by Frank Merkl View Post
# 9 brg is ford part#E6DZ -7G178-A or timken # FH-58073
#7&8 are GM# 9436851 and the one for the front planetery is Ford # F81Z-7A166-AA
Changing any of the other thrust washers will not help as they are not loaded or shouldn't be .
# 9 -shorten the oneway race to 1.010"
#8- machine the rear hub to fit the O.D of brg & I.D .050" smaller thanI.D.of brg .050" deep, machine back side of rear planetary .030" deep x.050" larger than O.D. of brg
# 7-machine the frt side of the planetary .040" deep same o.d. of the brg ( the brg is .140" thick & the stock thrust washer is .062", most C6's have way to much endplay , you want to have between .030-.045 end play when done , the orginal thrust washer race on the sungear shell can be removed to get the other .040" clearance here if neccesary)
# 5 Front planetrary already has 2 factory torringtons all you have to change there is the one thrust washer , the planetary needs the snout turned down .010" approx for I.D. of brg to fit (planetary's vary here)then machine face .040" deep x .050" larger than the O.D. of the brg , on the forward ring gear hub machine a groove .058" deep the same O.D. as the brg and .050"smaller than the I.D( Note the .050" on theses is for oil inlet clearance)
All cut should be done with a good carbide cut as the pins that are being trimmed are tool steel
Any Questions email me at fmerkl@eidnet.org
Pics http://www.putfile.com/pic.php?img=4392074
http://www.putfile.com/pic.php?img=4392073
http://www.putfile.com/pic.php?img=4392072
http://www.putfile.com/pic.php?img=4392071
http://www.putfile.com/pic.php?img=4392070
Sorry about the delay in sending
Frank Merkl
Matthew Moss
Old 01-27-2014, 05:11 PM
Garage
http://www.transmissioncenter.org/C6...Up_Diagram.htm
Based on this diagram I included in this post is there anyway Frank or somebody that understand how to rollerise the c6 can show me on the diagram where new parts are going and parts need machining I know this can help me explain to my machinist and help other newbie to. would probably need to print off and re-scan if possible
Frank Merkl
Matthew Moss
  #18
Old 01-27-2014, 06:37 PM
Frank Merkl's Avatar
Frank Merkl Frank Merkl is offline
Frank Merkl Driving a Ford
here's a link
http://s58.photobucket.com/user/fmer...sort=3&page=12
Frank
  #19
Old 01-27-2014, 06:41 PM
and the pics are all on post #15
Frank
  #20
Old 02-10-2014, 11:57 AM
Garage
Frank is it a good Idea to soak those BRG like the band and clutches in some tranny fluid before putting everything back together so that it gets lubed inside of the brg????.
Matthew Moss
  #21
Old 02-10-2014, 06:40 PM
soak them
frank
  #22
Old 04-05-2014, 09:32 PM
bigmat bigmat is offline
bigmat First On Race Day
Hi I maybe off topic a little but I have a newbie issue with a 1975 Valve Body and c6 trans,
I am wondering if I left a component out when I fitted the shift kit.
as I found this needle valve but am unsure if it even came from the auto. no spring seems to fit it nor no obvious seat for it to sit in.
Valve.
Any suggestions greatly appreciated. eg bin it...
  #23
Old 04-06-2014, 02:45 AM
gregaust gregaust is online now
gregaust Driving a Ford
Any chance you'd have a pic of the valvebody? Show the top of the manual valve . Some valvebodies have the detent in the valvebody, some are in the case . If I understand the issue you have the trans assembled? and there is no detent for the gears?? A 75 valvebody should have the case detent .
You in Australia too ?
  #24
Old 04-15-2014, 05:46 AM
Default VB from the top
Sorry I was waiting for a notification then realised I hadn't subscribed to the thread, as per attached pictures, thanks
I sorted the Detent the spring had just swung past the cam detent on the inner bracket. but I still need to know what the needle valve is for? Box is assembled
too thanks.
Mat
  #25
Old 04-15-2014, 06:14 AM
No idea what that pin is unless that valvebody had someones home made mors maybe ???
  #26
Old 04-15-2014, 06:21 AM
Yes I just dont lnow myself either. If nobody has seen a needle valve like it in a C6 before it is going to stay out.
(one of those ones when you walk with the VB in hand from the auto to the bench and happen to look down seeing the valve on the floor... and then you think why wasn't I paying more attention... lol
Thanks for your fast reply all the same
Cheers
Mat
  #27
Old 04-15-2014, 07:44 AM
stuarta stuarta is offline
stuarta Driving a Ford
Default Nope
I have never seen anything like that in a C6.
Wrench twister since 1957.
Journeyman in 1964.
Transmission builder since 1964.
