Valve Lash Adjustment Charts - 460 Ford Forum
Go Back   460 Ford Forum > Tech Topics > Engine Tech Archive
Engine Tech Archive A collection of all posts from the old Network54 forum
Old 01-17-2006, 01:14 PM
Danny Cabral's Avatar
Danny Cabral Danny Cabral is offline
Danny Cabral Driving a Ford
Default Valve Lash Adjustment Charts
Excerpt from Bret Powell's post on setting valve lash with big camshafts:
Adjust the intake when the exhaust starts to open.
Adjust the exhaust when the intake is almost closed...not when it starts to close.
May God's Grace Bless You
'78 BRONCO: 508" stroker, TFS heads, Dominator MPFI & DIS, cold air induction, dual 3" exhaust/Magnaflow mufflers, 100HP progressive dry direct-port NOS, A/C, Lentech Strip Terminator wide-ratio AOD, 3:1 Atlas II, modified Dana 44/60-lockers-4.10s, hydroboost/4-disc brakes, ram-assist/heim joint steering, Cage long radius arms, custom traction bars, 4" lift, 35" mud tires
Old 06-03-2006, 03:49 AM
tubais tubais is online now
tubais Driving a Ford
is there a method for hydralic lifters?? the motor is on a stand and new lifter. i heard there is a way to do it.
Old 06-15-2006, 01:57 AM
This is the sequence for hydraulic and solid camshafts.
Old 06-15-2006, 10:03 AM
thanks sir
Old 07-03-2006, 06:33 PM
Wildebill308 Wildebill308 is offline
Wildebill308 Driving a Ford
Thanks Danny!
Now I won't have to bother people with the same queston.
Old 11-07-2006, 07:09 AM
Tore Tore is offline
Tore Driving a Ford
Default Arrow Direction
On the top Valve Lash Adj. Chart by D.Davis I see an arrow that points clockwise,when you look at the rotor spin in the dist it spins C. Clockwise is this correct? :roll: Thanks Tore
Old 11-07-2006, 07:48 AM
Default Re: Arrow Direction
Originally Posted by Tore
On the top Valve Lash Adj. Chart by D.Davis I see an arrow that points clockwise, when you look at the rotor spin in the dist it spins C. Clockwise is this correct?
The curved blue arrow is illustrating the direction of engine rotation (when facing the front of your engine after opening the hood). This is also the direction you'll be turning the engine's crankshaft when going through the valve adjustment sequence.
The engine runs clockwise (facing front of engine).
The distributor turns counter-clockwise (as viewed from top).
http://www.boxwrench.net/specs/ford_429-514.htm
Old 11-13-2006, 11:58 AM
jrocco's Avatar
jrocco jrocco is offline
jrocco Driving a Ford
Default Re: Valve Lash Adjustment Charts
Would't the valve adjustment procedure change when using a performance camshaft?
Wouldn't changes in the duration and intake centerline affect which valves are at the bottom of the lobe?
Jerry Tomasello
70 Torino 429
Club Moderator - the Ford Torino Club
http://autos.groups.yahoo.com/group/TheFordTorinoClub/
Old 11-14-2006, 11:12 AM
No. (Unless you've done the '2-8' firing order swap, which is only for high output race users who wouldn't use this method for adjusting valves anyway.)
No. The valve is still closed on the base circle (bottom of a lobe, as you said) of each lobe.
Old 11-15-2006, 04:50 PM
jrocco's Avatar
OK so I flailed around about 4 times trying to get the valves adjusted right and finally called Comp Cams Tech Support.
So here's the story.
The charts above work for a factory stock cam. Once you install a performance cam you can disregard that information.
This is because the performance cam will have a different duration and different intake centerline that affects which valves are open at a certain point.
So the only way to adjust valve lash on a performance flat tappet hydraulic cam with adjustable lifters is as follows:
Remember EOIC (Exhaust Open - Intake Close)
For each cylinder, roll the crank until the exhaust valve just starts to open (move down) then adjust the intake valve to 0 lash and turn another 1/2 turn.
Then roll the crank until the Intake just starts to close (full open and just starting back up) and adjust the exhaust valve to 0 lash and turn another 1/2 turn.
Repeat for each cylinder.
Hope that helps. It worked for me.
Jerry Tomasello
70 Torino 429
Old 11-16-2006, 05:08 AM
Wrong! What size camshaft are you using?
When adjusting valves, you are on the base circle of each camshaft lobe. The lift, duration and separation angle are on the opposite end of the lobe...so why the heck would it matter (unless it's a radical cam with enormous lift and duration)? If your valves are open on the base circle of your camshaft, you've got a serious problem!
You're the first person that I've heard have a problem with the chart. Then you say it doesn't work with performance camshafts? I've got news for you...I wouldn't have posted this if it only worked with stock camshafts. Furthermore, I could care less what the Comp Cams 'tech guy' thinks he knows. I often link this page as a reference for others and now it's infiltrated with this useless dialogue!
Old 11-16-2006, 11:21 AM
jrocco's Avatar
Hi Danny
I did not mean to create a big argument here about valve adjustments or to upset you in any way. I was only trying to pass on the experience I had to help others that may have the same problem.
In my particular case the Comp Cams method solved a bogging problem that I was having above 5,000 RPM. When I set the valves using the Car Domain method, my engine pulled hard to 5,000 RPM then fell on its knees.
It only makes sense (to me at least) that the cam grind and how the cam is degreed on installation will affect when the valves are on the base circle of the cam as compared to the 0 reference point on the balancer.
If the cam is installed 4 degrees advanced or retarded, would not the base of the cam be 4 degrees off when the balancer is on 0?
Refering to the Car Domain chart, when you set the balancer on 0 and adjust No 1 intake, No 1 exhaust, No 7 Intake, etc, on a cam that is installed 4 degrees advanced you are not on the lowest point of the cam.
It also follows that different cam grinds affect the overlap of the intake and exhaust valves, so again the low point of the cam lobes can be different relating to 0 on the damper.
For all of those reasons I found that the EOIC method guaranteed having the cam lobe at the correct position to adjust the valve. After using that method, my engine pulled hard all the way to 6500 RPM when I shifted.
Jerry Tomasello
70 Torino 429
Old 06-16-2012, 07:36 AM
4604X4's Avatar
4604X4 4604X4 is offline
4604X4 Driving a Ford
Originally Posted by jrocco View Post
Hi Danny
Just to point out that whether the crank is rotated to "0" or "350" or "10" degrees the cam will still be on the base circle because the number of degrees of crank rotation from TDC (on compression stroke) is much more than 4 degrees. In other words when the engine is at TDC the valves don't start to move with just 4 degrees of crank movement. The base circle is from #9 to #6 on the profile drawing (actually a little more).
Old 06-16-2012, 10:51 AM
D Pope's Avatar
D Pope D Pope is offline
D Pope First On Race Day
Here's the cam profile chart for a 304 degree Isky solid cam. You can see that the valves are both closed for around 240 degrees. If you allow a bit for the clearance takeup ramp you'll still have around 200 degrees to work with. This won't change much with any camshaft. The valves can't be open on the power or compression strokes. That's why that chart has to work. Anybody who claims it won't better go back to elementary motor mechanics!!
1949 Mercury coupe
Nosed, Decked, Frenched
58 T-Bird interior
472 w/toploader 4 speed OD
Performer RPM w/Holley 3 barrel
Isky 304 degree solid cam
Narrowed 3.25 9.5 inch with Detroit Locker
Old 06-16-2012, 11:09 AM
jeffgfg jeffgfg is offline
jeffgfg Driving a Ford
I used this method for years on my 1970 Torino with a 429SCJ. I even put marks on the balancer so it was quicker to hit the marks. Just an interesting note my cam was advanced I think 8 degrees as per the Ford Muscle parts instructions and it always worked for me with over 30,000 street and racing miles on it. Wish I had that car back!!
