460 Ford Vs. 454 Chevy - 460 Ford Forum
Go Back   460 Ford Forum > Tech Topics > General Tech
General Tech A place to discuss general tech regarding chassis, transmission, tires, suspension, non-460, etc
Old 11-25-2007, 12:14 PM
tbolt tbolt is offline
tbolt Driving a Ford
Default 460 Ford Vs. 454 Chevy
This topic may have been covered already, but be that a Ford 460 and a Chevy 454 are similar in size and some people say in design. Which engine is better in performance? I Know it all depends on the build-up. It seems that Chevy performance aftermarket parts are much more abundant. My father-in-law just put together a 1970 Chevelle with a crate 454 Chevy. I want to be able to brag and tell him that my 460 Ford is faster and better! Ford and Chevy guys will probably be biased on there responses.
Old 11-25-2007, 01:43 PM
justintx75's Avatar
justintx75 justintx75 is offline
justintx75 Driving a Ford
stronger factory parts 460 hands down. the block it self is better, try stroking the 454 to 545.
93 coupe 11.97@113
429,c6,3.08
3485-LBS
472 W/ SCJ HEADS ON MY WAY TO LOW TENS IN A STREET CAR
Old 11-25-2007, 01:49 PM
cougarshaman cougarshaman is offline
cougarshaman Driving a Ford
http://highflowdynamics.com/
It all depends on the build, for sure.
But bench racing seldom comes from clear and lucid discussions.
The big chevy is a pretty good engine and certainly is no boat anchor.
I prefer Ford stuff because I like Ford's willingness to start with a clean sheet in order to make a better product/vehicle. If they had kept plodding along with the Y block or FE, I'd be a chevy guy.
1970 Cougar with a 429
Old 11-26-2007, 09:27 AM
What is the weight difference between the two engines? You referred the 460 to be a boat anchor, meaning it is heavier than the 454.
Old 11-26-2007, 11:05 AM
Danjet500 Danjet500 is offline
Danjet500 Driving a Ford
http://460ford.com/viewtopic.php?t=18724
You should read this. Just about covers it all.
513cid BBF in an FFR Replica
Old 11-26-2007, 11:50 AM
rmcomprandy rmcomprandy is online now
rmcomprandy Bleeding Blue
I certainly don't think anybody refered to the Ford as being a "boat anchor" just that the BB Chevy ISN'T.
The Ford IS considerably bigger in outside physical size dimensions and heavier.
www.rmcompetition.com
R.M. Competition - The finest Custom Engine Building for any venue ... !
Selling Parts and Supplies from companies I use ... 1(586)909-1591
CUSTOM ground camshafts
Carburetor modifications for specific applications
CNC porting
Old 11-26-2007, 11:53 AM
FORDBOYpete FORDBOYpete is offline
FORDBOYpete Driving a Ford
460 builders gotta have a clue what they're are doing to build & run a 460. But with a 454, if you can't build it you can always find 250 experts anywhere you look that can & will build it, and rebuild it, and rebuild it, until the pistons swap holes & it has to be replaced. They call 'em "Blow Ties" for a reason, doncha see?. :shock:
Hand Grenade is also an appropriate name for them. So Build your 385 series right & you can stay out front to avoid the hot oil & flying debris when the Oragne Replacement Enginess catastrophically fail on a pass. . .
IMHO :roll:
FBp :lol:
Change is the Only Constant
Old 11-26-2007, 11:46 PM
sledpuller sledpuller is offline
sledpuller Driving a Ford
If your waiting for a chevy guy to respond here,good luck.if there on here its to secretly find out what there doing wrong. :lol:.i can tell you on max effort deal useing oem heads and block,chevys will come up at least 50hp short of a ford.both motors having the same cu.in.There heads cant compete with a iron cj head. :wink:
Old 11-27-2007, 02:48 AM
ccso640's Avatar
ccso640 ccso640 is offline
ccso640 Driving a Ford
I'm in no way a Chevy supporter but I don't think its fair to compare an OEM 454 head to a 429CJ head. Seems fair to compare an OEM 460 head such as the DOVE-C or D3VE-A2A to the basic 454 head. I've seen some bone stock 460's that were pretty lazy, same goes for the 454 Chevy also. Be interesting to see what the OEM 454 head flows compared to the OEM unported 460 head. Chris
Old 11-27-2007, 04:28 AM
cougar1969 cougar1969 is offline
cougar1969 Driving a Ford
Chris the 454's some came with rectangle port heads but still don't come close to the CJ heads. but buck for buck the 460 can build more power than the chevy cuz the ford parts seem to be stronger and I like the simetrical port layout better.
454 4.25 bore x 4. stroke
460 4.36 bore x 3.85 stroke
the 460 to me has better torque cuz the bigger bore, I think the 454 most cubes you can do is 496 safely. now the 460 you can go 552 or 557 stroker. with stock block... now the chevy after tha 496 you better start looking at an aftermarket block.
Randy
Old 11-27-2007, 05:05 AM
ccso640's Avatar
My Dove-A block was good for 4.5 bore so 572 out of an oem block! Don't get me wrong, I love my BB Ford, second would be a Mopar. Chris
Old 11-27-2007, 07:27 PM
spyder70 spyder70 is offline
spyder70 Driving a Ford
i have both engines and still have my old street race camaro with a big block chevy in it. now on block strenght its about dead even but thats a ford cj and a bbc with 4 bolt mains. on bore size ford is king but most pre 79 bbc will go to .125 over.you can go .100 and never worry about sonic testing. chevy has a better oil system,ford has a better rod stroke ratio. a standard chevy head has a good and bad intake port (non symetrical) the chevy guys spend thousand to get what we have stock. most of the time when chevy head flow numbers are posted it for the (good) port so the same head has different flow depending on which way the runner turns. deck height ford wins heads wiegh about the same block wieght is about the same compared to a tall deck chevy 10.200.a stock chevy rod is stronger than a fords chevy has stronger cranks due to a factory forged unit that i have personally seen run at 1150 hp.ford has a larger diam. lifter so that better. i only raced a chevy due to price and availability now i wouldnt go back to a chevy but i think without this web site a guy could still strugle with the ford its hard to find people like charlie and lem and randy m, paul kane just to mention a few
Old 11-28-2007, 01:49 AM
HotRodLincoln HotRodLincoln is offline
HotRodLincoln Driving a Ford
Randy
GM's been selling crate and marine engines with 4.47 siamesed bore blocks for a while now. They were never installed in stuff with wheels but they are a regular production item, there's even an emissions-legal 502 truck engine. The bare block is about $1600 for the 'production' version, about $2K for p/n 24502502, their equivalent to A460. They sell a 572 crate engine as well.
The 460 is a newer design with some obvious improvements over the Chevy. But.. whoever designed in the crazy crank snout must have been fired from Mattel.
Old 11-28-2007, 10:10 AM
blue1978fordbronco blue1978fordbronco is offline
blue1978fordbronco Driving a Ford
Randy
IMO, that's the only thing GM has over Ford, aftermarket support. these GM guys don't look at it that way, but if they got the same lack of support that Ford did the tables would be turned. Why can't the aftermarket build blocks like that for Ford? Seems to me they would build some monster motors with Ford stuff if they wanted to but they don't.
1978 BRONCO 460 .030 35" Boggers locked front/rear
2008 F350 C/C Lariat 4x4 6.4 POWERSTROKE
2013 43' Heartland Road Warrior 415 toy hauler
2001 F350 C/C lARIAT 4X4 POWERSTROKE........sold
2004 F350 C/C lARIAT 4X4 POWERSTROKE........sold
