Go Back   460 Ford Forum > Tech Topics > Engine Build Archive
Engine Build Archive A place to archive DYNO or 1/4mile VERIFIED engine builds. Please post any engine tech questions to the Engine Tech forum.
Old 11-02-2009, 07:43 PM
Mizery Mizery is offline
Mizery
Default how bad does my stock c9ve intake hurt my hp
with my engine build how bad is the stock c9ve intake hurting me. or if some one knows how much it could be robbing over an after market intake.
here is my build
c9ve ported heads 2.19/1.75 valves
custom comp cam .588/.588 lift cam solid flat tappet
650 lift max valve springs
10 to 1 comp
h beam rods
probe pistons
stock intake c9
high volum oil pump
grind number 6259/6259
intake center line 109
duration @.50 intake 240 exhaust 240
lobe lift .3400 .3400
lobe seperation 113
  #2
Old 11-02-2009, 11:49 PM
Mark Miller Mark Miller is offline
Mark Miller is an unknown quantity at this point
Thumbs up
Here's some results from the Feb 1993 Super Ford magazine Dove-C heads and a 460 CI Engine cam was a .513 and .518 duration was 216 and 228 at .050.
Stock Intake=409.4 HSP at 5,000 rpm and 520 lb.tq. at 3,250 rpm
Offenhauser Portosonic=424.4 HSP at 5,000 rpm didn't give tq.
Ford Power Parts 4250=423.6 HSP at 5,000 rpm and 497.7 lb.tq. at 3,500 rpm
Weiand 8012=429.4 HSP at 5,000 rpm and 505.7 lb.tq. at 3,500 rpm
Ford Power Parts 4250B=433.4 HSP at 5,000 rpm and 508.7 lb.tq. at 3,500 rpm
Edelbrock Performer=434.6 HSP at 5,000 rpm and 518.9 lb.tq. at 3,500 rpm
Hope this helps would be interesting to see how the newer Performer RPM or Torker intake would have worked on that combo.
Later Mark.
Old 11-02-2009, 11:54 PM
Thumbs up
I would imagine the stock intake is hurting your combo quite a bit with that cam and ported heads.What size carb are you using?
Later Mark.
Old 11-03-2009, 07:17 AM
nuclearcobra's Avatar
nuclearcobra nuclearcobra is online now
Forum Contributor
nuclearcobra
I would jump on those victor intakes from Lem if you could i have a combo close to yours and took off the stealth 8012 and put on a victor and it was as responsive as the stealth and more up top and thats with the victor way off on the port match too the stealth was port matched perfect so i cant wait to see how the victor performs when its port matched.
84 hatch iron headed 472" on true 10.5 tires
Old 11-03-2009, 07:05 PM
Mizery
Later Mark.
i have a 750 holly carb.
Old 11-03-2009, 07:08 PM
Mizery
yeah i saw that the ports did not match. so it is possible to port match the victor to the c9 heads? my heads are a mild port. mainly removed the giant hump in the heads and cleaned up all the casting marks and milled out a little more. i will have headers soon on it. also would the victor handle a 225 shot of nitrous? also i found the stealth intake for 195 shipped new. good deal?
Old 11-04-2009, 12:10 AM
Thumbs up
More than likely it could probably use a bigger carburetor to IMO.
Later Mark.
Old 11-04-2009, 08:45 PM
Mizery
yeah it prob could use a larger one..
Old 11-06-2009, 06:38 AM
4door 4door is offline
4door is on a distinguished road
Default carb
carb is fine for street only use
Old 11-06-2009, 08:03 PM
Mizery
anyone want to takea guess on to how much hp it could be making with stock intake and the properly tuned 750 holly carb?
Old 11-11-2009, 08:33 PM
DJOHAGIN's Avatar
DJOHAGIN DJOHAGIN is online now
DJOHAGIN is an unknown quantity at this point
Is this a street engine? If so, how much time are you spending above 4000 rpm?
Dave
Old 11-12-2009, 02:46 PM
Mizery
Dave
it is a weekend street/track car. and right now itsonly seen over 4000 rpm 3-4 times. but it hasnt been to the track yet. but im sure it will see above that quite a bit on the weekends.
Old 11-15-2009, 11:08 AM
rmcomprandy rmcomprandy is online now
rmcomprandy is on a distinguished road
I would speculate there would be about a 50 horsepower increase going to a "Torquer II" intake manifold.
www.rmcompetition.com
R.M. Competition - All Custom Engine Building of any type at its' Finest...!
Parts and Supplies from just about everybody; whatever's necessary ... 1(586)909-1591
You may not post new threads
You may not post replies
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
