Go Back   460 Ford Forum > Full Race Tech > 4x4's, Pullers, Crawlers and other HD rides
4x4's, Pullers, Crawlers and other HD rides We don't need no stinkin' asphalt!
Old 11-05-2009, 11:33 PM
PHIL1206's Avatar
PHIL1206 PHIL1206 is offline
PHIL1206
Default hey pullers
who makes a good spool for a dana 80 other than the $1250 haisely one also anything need beefed up while im in the mock up stages
we're all friends till they wave the green flag
Old 11-06-2009, 02:54 PM
hookin78's Avatar
hookin78 hookin78 is online now
hookin78 is on a distinguished road
Lincoln, century, Miller, Hobart.......... lots of companies.
No, but seriously,many guys around here just weld them up, I just done a Dana 80 a couple months ago.
Old 11-06-2009, 11:18 PM
PHIL1206's Avatar
PHIL1206
i seen yukon makes a spool for $650 how about puttin bridge from the backing plate flange under the pig to the other backing plate flange
Old 11-09-2009, 03:56 PM
hookin78's Avatar
That would help eleminate some flex but I don't really know if it is needed, 14 bolts benefits from this but I believe and 80 would be OK without.
Old 11-09-2009, 06:19 PM
PHIL1206's Avatar
PHIL1206
as much those axles go for maybe i should brace it my hitch works from the bottom side of axle and traction bars off top side
Old 11-10-2009, 05:21 PM
hookin78's Avatar
Good call.........
Old 11-10-2009, 05:49 PM
PHIL1206's Avatar
PHIL1206
Default hey holokin78
what class you pull in where your at theres some pretty tough trucks down your way
Old 11-10-2009, 10:34 PM
hookin78's Avatar
I just run the street stock class right now, I have built a few others , I am currently putting together a cheater stock truck (Cast heads, NO dommies, 514 cubes) for a freind and hoping to get started on my ProStock motor soon.
Old 11-11-2009, 05:24 AM
PHIL1206's Avatar
PHIL1206
whats your pro stock rules can you send me a copy of them
Old 11-12-2009, 08:30 PM
hookin78's Avatar
The best thing to do would be to follow this link.......
http://truckpulls.com/forum/viewtopic.php?f=45&t=802
This pretty much covers everything , and more, lots of good info on this website also.
Old 11-12-2009, 08:42 PM
PHIL1206's Avatar
PHIL1206
thank ya oh by the way thats a good lookin ol ford ya got
Old 11-12-2009, 10:17 PM
hookin78's Avatar
Thank ya............
Old 12-07-2009, 06:37 PM
mikejvan mikejvan is offline
mikejvan is on a distinguished road
Default axles
i run a 70 with welded gears in a super stock class never had problems in so far 12 years but gm 14 bolt have a lot mor option;s that a dana 80 and a 3rd pinion bearing where the 60/70/80 dont
Old 12-10-2009, 06:59 PM
bmkelley1's Avatar
bmkelley1 bmkelley1 is online now
bmkelley1
Default spool
I see scs makes a spool for a dana 80
Kelley Pulling
Pull it till ya blow it !!
Old 12-10-2009, 07:08 PM
bmkelley1's Avatar
bmkelley1
Smile 80
I used to run an 80 with 4.62 gears and wire welded spiders with no problems, and it was behind a 532 motor with 900 hp. I wouldn't think u would have a problem with one unless it bounced like a yo-yo. lol
Kelley Pulling
You may not post new threads
You may not post replies
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
