Go Back   460 Ford Forum > Full Race Tech > Driveline
Driveline Transmission, Clutch, Gearing, etc...
Old 11-02-2009, 07:16 AM
humaxxx humaxxx is offline
humaxxx is on a distinguished road
Default Line pressure C6Transmission
Hello,
Can somebody tell me how you to increase the line pressure of a c6 transmission
Thx
Old 11-02-2009, 09:32 AM
crittersf1's Avatar
crittersf1 crittersf1 is offline
crittersf1
Send a message via AIM to crittersf1 Send a message via MSN to crittersf1 Send a message via Yahoo to crittersf1
Frank, I believe this one's for you!
Old 11-07-2009, 02:24 AM
nobody???
Old 11-09-2009, 06:26 PM
Frank Merkl's Avatar
Frank Merkl Frank Merkl is offline
Frank Merkl is an unknown quantity at this point
By changing the pressure regulator spring, the baby blue ford rear brakeshoe retaining spring will boost line pressure to 150 psi
Frank
Old 11-15-2009, 01:17 AM
rat poison rat poison is offline
rat poison
Is that brake spring for a standard ford 9 inch brake?And is this above a manual valve body or is that mod. already done?{turbo action cheetah manual reverse valve body]
You want to race for cheap? Drive a chev. If you want to win? Drive a FORD!
Old 11-16-2009, 02:04 PM
OK Frank.
I have an Artcarr VB. Is it necessary to chance this spring.... or is it already OK.
I have a 522 ci engine (750hp) and a 3300 lbs car.
The trans has already the following things:
- wide ratio kit
- 6 plates in both clutches
- wide kevlar band
- R servo
already thanks
Freek
Old 11-16-2009, 06:08 PM
should be okay
Frank
You may not post new threads
You may not post replies
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
