| 4x4's, Pullers, Crawlers and other HD rides We don't need no stinkin' asphalt! |
Thread Tools | Search this Thread | Display Modes |
I got a 1989 F350 Crew Cab Long Box that I am rebuilding the engine. What I am really looking for is my 466 to put out lots of torque, sound really mean and keep it on pump gas. Before tearing it out it was getting 12MPG on EFI, I later found out cylinder #7 wasn’t firing due to an oil leak inside. Hoping to keep it in the low to mid teens MPG after the build. That is before I throw on a 9 inch lift and 35” tires.
Bored it .030 over New pistons (Stock replacements +.030) Polished the crank Main cap studs Head studs New heads D3VE-A2A Exhaust headers New water pump Gear to gear timing Hydraulic lifters 4X4 Extreme Cam (Comp Cams .514 lift #FFX4256H11) New pushrods Remote dual oil filters Re-ring on the flywheel Dual 14” electric fans Holly truck avenger carburetor 770 CFM 2” Carb spacer Torker intake manifold Stock rockers (don’t want to machine the head to install roller rockers, plan on doing that later) Right now I have run into a few snags: Cant find the correct intake and exhaust gaskets for the D3VE A2A Heads New high flow oil pump wont fit stock oil pan (plan on welding up my own later on, and to keep stock for now) I don’t know the correct clearance between the oil pickup and the pan (all stock for now) IF ANYONE HAS ANY HINTS TRICKS ADVICE PLEASE GIVE ME ALL YOU GOT! Out in Minnesota so no emissions test necessary. |
| Sponsored Links | |
Advertisement | |
#2
nice lookin truck
things i'd change would be the intake. id go with a dual plane...performer 460. D3 heads take same gaskets as Dove heads. Edit: i thought you had torker 2... idk how good the torker is at lower rpm.
*The DEADLIEST Keyboard Warrior* Whats an LS ![]()
Thanks,
I have the performer 460 but I thought the torker might be better. Whats the diffrence in power between them?
89 F350 CrewCab Long Box 466CID |
Higher revs but you will loose some of the street-ability. Edit while they are out grind out the smog humps on the exhaust side ports. |
WTF would you put a 9" lift on a CC LB and use 35" tires? I can fit 35s on my 1990 CC LB with stock suspension. Nine inches of lift, PAH!!!! You could fit 44s with 9" of lift.
Wooo Sahhh. As far as suspension lift and bigger tires go, use a Sky Manufacturing 3" Shackle Reversal kit in the front, a shackle flip in the rear with 6" lift springs, get rid of your factory lift block, and have an F-350 that rides like an F-150. Taller is NOT better, nor is it cool. A low center of gravity, great ride and articulation, with the biggest tire possible, now thats cool. And thats what the above setup will do for you. Tell me what tranny you are running, and I'll tell you what axle gearing you need. The first step towards both good fuel economy and great torque is getting your drivetrain geared correctly. |
i dissagree with pitbull on that one, more clearance in the fenderwell looks 10x better then tryin to see how big of a tire you cant stuff in there,
but at the same time im agreeing with you on the fact that 35's are way to small for that i got a 77 highboy with 3 inch leaf blocks and i got 35's that fit perfect |
I'm not talking about having a wheelwell full of tire that rubs on everything every time you turn the wheel, I'm talking about having this:
http://www.pirate4x4.com/forum/showthread.php?t=852507 instead of this: http://www.thprd.com/imagelibrary/im...r%20Truck1.jpg or this: http://www.diseno-art.com/images/bigfoot_5.jpg |
I'm just trying this out, if it doesnt work out I can allways cut it out.
89 F350 CrewCab Long Box 466CID Last edited by 89F350; 06-09-2010 at 10:17 PM. Reason: more info |
I am pretty sure the transfer case and diff are stock. I’ve done a little research and I think I have a Dana 60. That’s a few projects away but I’ll be tearing into them and rebuilding them soon, hopefully puting new gears in.
Does anyone know the stock gears for my truck? (89 F350 CrewCab LongBox 7.5L)
granted its older and its a F-150 But i like my truck setting like this on 35's.. ![]() Quote:
Larry (SLIM) 77 F-150 BB on 38's |
![]() 89F350, are you talking about basically flattening out your wheel wells in the bed, or making your wheel opening on the fenders smaller? The former seems like a cool idea, the latter seems a little... Caddilac, lol. Be sure to show us if you do it. Last edited by Redpitbull44; 06-11-2010 at 06:59 PM. |
I was planing on choping the wheel wells out and welding in a lower resses. That way there is still room for some up travel, while freeing up some bed space. So kind of a little of both.
I have to give it to you there. Normaly I say more lift the better, but that trucks sitting pretty badass right where it is.
Does anyone have a vacuum diagram for this truck? (89 F350 7.5L/460) Or any similar vehicle of the same year?
| Display Modes | |
