home tire cutting - 460 Ford Forum
Go Back   460 Ford Forum > Full Race Tech > 4x4's, Pullers, Crawlers and other HD rides
4x4's, Pullers, Crawlers and other HD rides We don't need no stinkin' asphalt!
Old 04-13-2011, 10:25 PM
kjett's Avatar
kjett kjett is offline
kjett Driving a Ford
Default home tire cutting
Figure'd I'd post this up for you guys that have thought about doing this. Let me start out by saying that I bought a set of home cut 39.5x18 boggers that just had the small lugs ground off a few years back and have been slowly touching them up ever since. Here is what they looked like when I bought them:
My buddy and co-builder took some time with a 90* small air grinder and sanding disks to clean them up, smooth and back cut the lugs and used a grinder wheel to start the scooping process of the lugs. Pic in progress:
I ran them like that for the last 2 years and I finally decided they were not light enough so I bought a tire groover from Speedway motors. It's the cheap 250 watt unit that comes with a #4 head and blades. I bought the #8 head and flat bottom blades as well and have been slowly playing. So far I cut the sidewalls and working on the main tire carcass and have cut around 7/32 out of the center but around a 1/4" from the outter edge/corner radius of the tires! This process has been time consuming and I only get time to do a little at a shot, but I can already feel the weight different of before and after. I am down to the thin rubber membrane just above the cords and will leave it there. After I get the other tire cut down to the same, I will open the depth of the cutter and scoop the lugs more. Here's another pic of the start to where I'm cut to on the side for reference:
I'll keep updating with pics when I scoop out and back cut the lugs for finals. I'm just posting this for those that have a set of older tires and can't afford new cuts so you can do it yourself and get a little better traction in the process.
Old 04-13-2011, 10:31 PM
crittersf1's Avatar
crittersf1 crittersf1 is offline
crittersf1 Driving a Ford
Send a message via AIM to crittersf1 Send a message via MSN to crittersf1 Send a message via Yahoo to crittersf1
Turns into a "JOB" real quick
If you're not living on the edge you're taking up too much space!
Old 04-13-2011, 10:33 PM
kjett's Avatar
Yeah it does! It's easy as can be cutting just under an 1/8" at a slice, just takes a while with all that rubber. I already have a huge pile I'm keeping together to weigh for after they are all done. Curious how much I'm actually "shaving" off of that rotational weight.
Old 04-14-2011, 08:09 AM
Broncoholic's Avatar
Broncoholic Broncoholic is offline
Broncoholic First On Race Day
I blew thru the center of my 39.5 & it is only 1/4" to the cords. 3/8th to the air. & these were new un cut. Pretty skinny on the center mold parting line.
Are they going to make Bogger's ever again...
Old 04-14-2011, 09:11 AM
Mud Freak's Avatar
Mud Freak Mud Freak is offline
Mud Freak Driving a Ford
thats an understatement
IIRC I lost 25+lbs of mine without scooping the lugs.
When in doubt, hold'er to the floor.......I'm usually in doubt.
http://www.youtube.com/user/mudfreak79
President of the P.C.O.R.A.
Old 04-14-2011, 02:50 PM
Touchngo's Avatar
Touchngo Touchngo is offline
Touchngo Driving a Ford
your doing a great job karl, I bought the same knife and cut mine 2 years ago and I din't get any where near as much done as you have, I gave up, and I have my tires for sale with the knife, and I'll just save a little more and buy them cut before I do that again, Scott at racinginthedirt.com is very reasonable priced and does an real nice job
Steve
2001 Ranger mud drag racer
632 ci with C heads and 2 -1150's
Old 04-14-2011, 08:27 PM
kjett's Avatar
Thanks Steve. Just came in from doing more. I don't have the blade set really deep and after several passes between each lug, I'm down to where the thin rubber membrane over the cords. I'm putting all the shavings in a pile and will get a pic when it's all done to show how much I cut out.
Old 04-15-2011, 06:00 AM
crittersf1's Avatar
Steve
Still for sale? What size and how much?
Old 04-15-2011, 06:08 AM
kjett's Avatar
Funny, I was just thinking that this morning. You still got them old 38.5's? Worth cutting for fronts?
Old 04-15-2011, 06:11 AM
kjett's Avatar
Where do you cut tire guys do for tubes? I've got a couple spots where I actuall went a little deep and the cords are showing. There is no air in the tires now and wondering if it's worth putting tubes in to be on the safe side.
Old 04-15-2011, 06:19 AM
crittersf1's Avatar
There are a couple of spots like that on my Jimmy Dean cuts, I've never worried about them. I don't have any extra 38.5's right now
Old 04-15-2011, 06:32 AM
kjett's Avatar
No prob. Lloyd Fritter has a set of 39.5's he started cutting the lugs off and stopped. He gave me a hell of a price, but they are the same size as my rears, and I was hoping to go a little narrower on the fronts.
Old 04-15-2011, 09:17 AM
Touchngo's Avatar
Talking
still have them, there 39's, were like new before I started cutting them,
asking $600 for the pair and the cutting knife with 2 different heads. here's the ad on kijiji, I am in ON,Canada but I am heading to Ky next weekend. going to see Lem and Charlie
http://toronto.kijiji.ca/c-cars-vehi...AdIdZ269005031
Karl I wouldn't wrorry to much about getting tubes, there's a guy up here that has cords showing all over and some of them are even cut and he doesn't have tubes,(they are on a rail though)
Steve
Old 04-15-2011, 09:41 AM
crittersf1's Avatar
I was hoping that they were 44's
Old 04-15-2011, 11:35 AM
kjett's Avatar
I know a guy that has some 44 cuts on wide 5 wheels I was thinking of trying out and put my 39.5's up front. Not sure how it'll work out though...
