Will old style A heads work with flat top pistons?
4K views 3 replies 3 participants last post by  steve1071
#1 · (Edited)
Hello Jon ,
will the old A heads just bolt on a motor with flat top pistons? or are the valve angles to far off? Thanks.
Rick Skaggs
#2 ·
Not Jon, but they'll bolt on.
Now in regards the valve notches, if the pistons are for standard, stock style heads, you'll need to either:
a) Put new valve notches in them.
b) Get new pistons.
And yes, they have completely different valve angles.
Hope that helps,
Dave
#4 ·
My first set of a heads I cut the valve reliefs in the old pistons by putting a cutter in the guide and put the head on the motor and using a drill cut the reliefs ,maybe not the best way but it worked .
