Ive been wondering if anyone can help me pick out the right combo...the engine will be used for running at bonneville speedway...under the class....a/bgc.....my engine size class is from 400-500.99ci...it will be a blown engine...procharger f1-r..intercooled...about 15psi...the engine will be a carb setup..in a 05 mustang...without the factory wiring harness...i would like to see the 1000hp range with boost...and be in the upper 7500+ rpm...the help i need is guidence in choosing the correct heads and cam....ive already got the block...its a eliminator billet 385 series.....ive received and read great info on the p51 heads from kaase...with a high rev kit....i just need a cam..but.if anybody knows of a better setup..i could use the help....thanks....
