460 svo how much larger?????
8K views 9 replies 7 participants last post by  WFO
#1 ·
I have a BBf 602 cube, c headed, motorsport intake, stock 1250 holley that had a nitrous cam in it, roush/yates removed it and installed a hp roller cam, intake 861 exh 839. 114 intake centerline, duration @ .050 intake 285 exh 308. - 4.6150 bore 4.5000 stroke it made 1090 hp @7100 rpm 867 torque @6000
how many more cubes can i get out of this block?
#8 ·
so you can get 605 with a stock dove A block or d1,d9 and 635 with a svo?
what can you get from a A460 and eliminator?
Im looking to move up from my 557 doveA with 4.500 stroke, 4.445 bore , 6.8 rod
Id like to do a aluminum rod 632. Can a A block go bigger than 632 or is it a 1 time deal?
All info appreciated.
#9 ·
Block
No, probably the max with a stock type block is 572" (4.5 x 4.5) if you can even find one & get it to bore 4.50".
Not counting deck plates to make a taller deck stock block which may not be worth the trouble and alot of work.
The SVO block he has will go to a 605" with a 4.5" stroke, 635" with a 4.75" stroke.
FWIW Mark
