After sitting for the winter I had some pretty bad leaking from my transmission.
I have purchased a new aluminum pan, but I also notice a drip on the shifter shaft on the side of the tranny.
While I am changing the pan I want to change the shaft seal as well and be done with it. I know I have to drop the valve body to remove the shift lever since I already did this before when I was modifying the shifter arm to work with my column shift.
Does the shaft seal press in from the outside of the housing or from the inside?
Does anyone have any tips for removing and installing the seal? Is it a tight fit?
