Engine Tech A place to discuss all 385-series engine tech and theory
Old 11-05-2009, 08:42 PM
Trent Trent is offline
Trent is on a distinguished road
Default Max HP a 1970 460 block can take?
Hi All,
Great forum here!
Could someone englighten me as to what the max hp a 1970 460 BLOCK can take with the 2 bolt mains and how much if I convert to the 4 bolt main caps.
Thanks in advance!
Trent
Old 11-05-2009, 09:35 PM
Dukeofdiamonds Dukeofdiamonds is offline
Dukeofdiamonds
Send a message via AIM to Dukeofdiamonds
It depends. Not all blocks were created equal... but most have agreed that any factory 2 bolt block is usually fine to 700 hp. There are those that have successfully pushed these blocks to 1500 hp before..... but these people are not the average builder and its only a matter of time till something breaks. Most guys will go to an aftermarket 4 bolt block or at least machine and install 4 bolt caps for anything above this level. The BBF is a strong motor, but there comes a point where there is a gray area where safety and reliability are at risk.
What really depends is, what are you wanting to do? Best bang for your buck? Stroker motor? NOS? Forced induction? That will determine how much work it will take to meet your goals, and whether or not a factory block is appropriate.
Also, don't hesitate to do a search on here, there has been lots of information posted in the past.
Dave
If you cant get it, you aren't using a big enough hammer.
83 F-250 "Dave Force One"- daily driver/towmobile. 472, C6, NP205, D60 front/10.25 rear soon to be on 37s
83 Mercury Capri 466/C6- under construction
Old 11-05-2009, 09:45 PM
Hi Dave,
Thanks for the information. I am building a stroker 521 drag motor and looking for 850-900 hp at the crank N/A. I already have the block and would like to have it machined for the 4 bolt caps and put a forged rotating assembly into it. I was wondering if 900 hp would destroy this block... I also don't like to live on the ragged edge if you know what i mean
Thanks,
Trent
Old 11-05-2009, 09:57 PM
1Bad65's Avatar
1Bad65 1Bad65 is offline
1Bad65 is an unknown quantity at this point
If you plan to make that kind of power....it's un-realistic to not go with a A460 aftermarket block. It's not worth the "I think it will hold pass after pass after pass".....I'd spend the $2500 and get that block if thats the power you want to make. If you stay under 850hp I think a 4bolt splayed would be ok, but any more it isn't worth the headache and pain to go through after you $$$$ is demolished over a block that could hold up to the power inside of it....jmho
Old 11-05-2009, 10:06 PM
Dukeofdiamonds
X2.
You have the right idea not to run on the ragged edge... its always better to spend the extra for the better stuff, 99% of the time it ends up being cheaper in the long run.
Dave
Old 11-06-2009, 07:19 PM
DJOHAGIN's Avatar
DJOHAGIN DJOHAGIN is offline
DJOHAGIN is an unknown quantity at this point
Trent,
While it is certainly possible to make the stock block work, and work well, you're at a point where the A460 block or an Eliminator block is a better choice. You can start off the bore at 4.5, which will help with unshouding the valves, and I'm assuming you're looking at the A460 heads. While you can get the stock layout heads to put out that kind of power, if you're starting from scratch, the A-heads would be better.
Hope that helps,
Dave
Old 11-06-2009, 07:32 PM
MarkJ MarkJ is offline
MarkJ
Default Save for aftermarket block
They can also split from the mains to the cam. I have one that was making around 825H.P.
V/R
MarkJ
Old 11-06-2009, 07:39 PM
Lem Evans Lem Evans is offline
Forum Contributor
Lem Evans is an unknown quantity at this point
V/R
MarkJ
Yep...if they [2 bolt deals] break it's from a main bolt hole to the cam bearing housing .
www.bfevansraceparts.com
Old 11-07-2009, 06:24 AM
HEMI-HUNTER HEMI-HUNTER is online now
HEMI-HUNTER is an unknown quantity at this point
i wouldn't worry to much about 900hp as long as you stud the mains w/ a girdle. and use quality forged parts in the bottom end don't bore over 80 and make sure she is balanced to the T". it should hold up OK. try and keep it under 7000-7200 and make sure the block is sonic checked before you bore it 80 over.
70' Maverick tube chassis front strut, fiberglass flip front end, 557 A-Head 8.90's...1969 #MATCHING MACH1 428 CJ RESTORED 1 of 1....1970 HEMI CHALLANGER
Old 11-07-2009, 07:28 AM
BBFmavrick's Avatar
BBFmavrick BBFmavrick is offline
BBFmavrick is on a distinguished road
Also, You have to remember that these blocks are 40 yrs. old. KISS
(LIL TWEETY) BBF 62 Falcon Tube Chassis
Member of a BAND OF BROTHERS
Thanks to my sponsors for 2010
Pro Motion Machining
Perfect Reflections Photography
Bronx Corner Automotive
Old 11-07-2009, 12:07 PM
Paul Kane's Avatar
Paul Kane Paul Kane is offline
Super Moderator
Paul Kane is on a distinguished road
Cool
Originally Posted by Trent View Post
Could someone englighten me as to what the max hp a 1970 460 BLOCK can take with the 2 bolt mains...
Depending on engine combo, engine application, components used, compression ratio, hp generated, operating rpms, executed block modifications/preparation/treatment, power adders, tune, and more: the 2-bolt blocks can support anywhere between 300hp-1500hp. Generally, the higher the power output the riskier the use of the OEM block and the greater the maintenance (maintenace exponentially increases, so to speak). So they have lived at 1500 hp but these engines usually received complete freshening after 7500 feet worth of quarter-mile passes, and on the flipside I have known people to absolutely destroy 4-bolt blocks at just 300 hp.
Like Chuck Stevens signature line states, "Some people can break a cannonball, in their little sandbox, with their bare hands."
We're On The Web; Click Below:
High Flow Dynamics
Performance Components for the 429/460 Engine Family
Old 11-07-2009, 01:24 PM
1Bad65's Avatar
IMHO, older is better, but with today technology....it's priceless
Old 11-07-2009, 01:30 PM
1Bad65's Avatar
lol, very well stated and I can see where your coming from. BUT, to me it's just foolish to waste your hard earned dollar to make HP levals that were never really thought of when these older blocks were designed. Thats why these A460 blocks are worth the money. They have been proven to hold up to 2500hp. Now if you ask me....if I'm gonna make 900hp NA w/out gas and then plan to spray...There is no way in hell I'm going to limit my block power to 1500 when I'd much rather limit my block power to 2500hp...plus that motor making 900hp in a A460 block has room to grow and MUCH more room to play..
Old 11-07-2009, 02:01 PM
Paul Kane's Avatar
Super Moderator
Cool
Yes, if you can afford 1500-2500 hp, then hopefully you can afford to use parts superior to OEM passenger car parts.
High Flow Dynamics
Old 11-07-2009, 03:06 PM
1Bad65's Avatar
hey I'm a poor guy....i cant afford no a460 block myself....so i just stay under 800hp.. Thats plenty for me to handle...
You may not post new threads
You may not post replies
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
