Crankshaft balancing
2K views 11 replies 7 participants last post by  tconnection
#1 ·
Does the machine shop need the complete rotating assembly to balance a crank?
I mean, does he need all of the pins, rings and bearings
#2 ·
piston , pins , rods, crank , flex or flywheel, balancer 1 set of rod bearings, 1 set of piston rings make sure they stamp your crank with the bob weight for future use its good to have piston and rod weight stamp to that way u wont lose them
dragweek quickest street rod
2009 2010
#7 ·
Ok, i got my rotating assembly back from the machine shop and as far as i can see it all looks good. It didnt need any weight add. Looks like the front counter weight got drilled alot and one of the drill holes got a little thin to one side. Is that ok? Im gonna mic it again tonite and i think the oil slingers color is slightly differant. Would that be from the cleaning?
#8 ·
Location of the drill holes is not vert important. Even breaking through on one side happens quite often when a lot of weight is to be removed. Looks ugly but, structurally doesn't matter.
