Engine Tech A place to discuss all 385-series engine tech and theory
Old 06-05-2006, 08:51 AM
tubais tubais is offline
tubais
Default valve adjustment "hydraulic"
is there a method for adjusting hydralic lifters?? the motor is on a stand and new lifter. i heard there is a way to do it. This hasn't been started so the lifters aren't pumped up.
Is it safe to turn the motor over when the lifters are soft?
Old 06-05-2006, 09:59 AM
TRUKPULR's Avatar
TRUKPULR TRUKPULR is offline
TRUKPULR
I'd just prime the engine using a 5/16 1/4" drive socket and 8" extention on a 1/2" Drill.. run the drill in revese this will pump up your lifter and then you can set the preload.
ShaZam
You may not post new threads
You may not post replies
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
