Preventive Maintence for Racing Engines - Page 3 - 460 Ford Forum
Go Back   460 Ford Forum > Tech Topics > Engine Tech Archive
Engine Tech Archive A collection of all posts from the old Network54 forum
  #31
Old 05-06-2007, 08:40 PM
bigpoppapreston bigpoppapreston is offline
bigpoppapreston Driving a Ford
there is a wealth of knowledge to be had here for no charge and this thread is no exception.
for me, a family man that makes only $60,000 a year (from my job) excluding side hustles, spending ~$20,000 just for a motor is a big deal. it behooves me to take all these nuggets and precautions neccessary to have a worth while program.
kudos to charlie and everyone who share their experiences free of charge and without being cocky and indifferent.
460ford.com rocks and rule! 8)
Old 12-29-2007, 03:43 PM
Paul Kane's Avatar
Winter 2008: Bump to a noteworthy thread for those of you that should perform some Off Season Maintenance.
Paul
High Flow Dynamics
  #33
Old 12-29-2007, 04:09 PM
hotrodmerc's Avatar
hotrodmerc hotrodmerc is offline
hotrodmerc Driving a Ford
The PM is so true. My brother runs an AMC and uses a System 1 oil filter. After a weekend inspection we seen what looked like some bearing material. Pulled engine and tore apart. Sure enough thrust bearing was cut on a little. We ended making a thicker mid plate because of the load on the back of the crank. The good PM saved the engine. Only put in new bearings and the mid plate,,, problem solved.
http://i239.photobucket.com/albums/f...ebsightpic.jpg
1970 Cougar Eliminator
512ci
10.42 ET 133mph
All Motor@3750LBS
  #34
Old 12-29-2007, 07:48 PM
2112's Avatar
2112 2112 is offline
2112 Driving a Ford
Paul
Thanks!
I WANT one of those Buxton spring testers! I wonder if I can adjust the length of the rod connecting to the T-handle so it clears my marine headers when I apply force?
  #35
Old 12-29-2007, 11:55 PM
Larry T's Avatar
Larry T Larry T is offline
Larry T Driving a Ford
can some one put up new links as to the spring tester we need?i tryed the old links and nothing came up or was unavalable.
maybe i found it....
http://cgi.ebay.com/ebaymotors/Profo...spagenameZWD1V
  #36
Old 12-30-2007, 07:03 AM
bruno's Avatar
bruno bruno is offline
bruno Driving a Ford
anyone have those charts or forms the can email me ----
thxs
  #37
Old 12-30-2007, 12:33 PM
2112's Avatar
2112 Driving a Ford
htthttp://cgi.ebay.com/ebaymotors/Proform-67597-Valve-Spring-Pressure-Tester-JEGS_W0QQcmdZViewItemQQ_trksidZp1638Q2em118QQcateg oryZ46093QQihZ008QQitemZ180192886528QQrdZ1QQsspage nameZWD1V
http://www.buxtonengineering.com/vst_600.htm
  #38
Old 12-30-2007, 01:17 PM
c.evans c.evans is offline
c.evans Driving a Ford
Guys,
Brad Buxton is one of our local boys. I invited him to be a quest speaker at our recent Winter Tech Seminar and talk about valve springs. He was planning to come, however the flu bug is going around, his wife and kids got it first and then he was sick Saturday, so he didn't make it.
Brad used to build NHRA Pro Stock engines, but when that team closed the doors, he started making all of these valve spring testers and etc. Probally each Pro Stock team out there, has his testers. Most likely two of them. A bench mount in the shop, and the on engine tester in the trailer.
His testers are certainly high end products. You can buy them direct from Brad, or you can buy them from me. We're friends and go back a ways and he sorta' made me a dealer. Either way the price is the same, but if I can help you, I'm more than willing.
Hope this helps,
Charlie Evans
  #39
Old 01-05-2008, 12:33 PM
2112's Avatar
2112 Driving a Ford
Brad saw my headers and thought it may not be possible :?
He is working on a new tester as we speak. hopefully it will help. I suggested a longer rod from the handle to the base under the gauge.
Charlie, I took the liberty of reposting your original post on Offshoreonly.com
in the technical section as it answers so many questions asked over there as well , I hope that is OK
http://www.offshoreonly.com/forums/s...36#post2394436
  #40
Old 01-05-2008, 06:24 PM
TravisRice TravisRice is offline
TravisRice Driving a Ford
I have the Buxton tester and spring changer both for our C-heads. Definatley a top quality peice, something that you can not do with out.
Travis
  #41
Old 07-14-2009, 10:14 PM
DJOHAGIN's Avatar
DJOHAGIN DJOHAGIN is offline
DJOHAGIN Driving a Ford
Bump for the new members.
Dave
  #42
Old 07-14-2009, 10:42 PM
mguy's Avatar
mguy mguy is offline
mguy Driving a Ford
I'm not new, but this post is a Gem! Thanks for digging it up, Dave, and feel free to dig up more good'uns.
The Original "RedneckProfessor"
  #43
Old 07-15-2009, 12:02 AM
deliveredfast's Avatar
deliveredfast deliveredfast is offline
deliveredfast Driving a Ford
wow! that was a great bump. I had never seen this thread. very valuable info.
BBF IDT SHORT BLOCK
18bolt TFS A460 heads
CNC'D by SVRE
TFS Intake ported (SVRE)
COMPCAM by BLAKE
http://i287.photobucket.com/albums/l...ps5280b9cf.jpg
  #44
Old 07-15-2009, 08:24 AM
Copperhead Copperhead is offline
Copperhead Driving a Ford
Originally Posted by deliveredfast View Post
very valuable info.
Yep,...... I have to agree.
  #45
Old 08-31-2009, 09:37 PM
mudbogtom's Avatar
mudbogtom mudbogtom is offline
mudbogtom Driving a Ford
Send a message via Yahoo to mudbogtom
ttt
Tom
Soon to be powered by...
www.carsbycarl.com
