Looking for 4 bolt main 460 block - 460 Ford Forum
Old 08-27-2006, 01:56 PM
pencilneck pencilneck is offline
pencilneck Driving a Ford
Default Looking for 4 bolt main 460 block
I'd like to build up a stroker 460 engine for the street and was wondering how I would identify a 4 bolt main block? I've heard some DOVE blocks have 4 bolts, so I'm going to start checking out all the cars for sale in this area to look for one plus I guess I could start looking on ebay... Would like to avoid shipping charges, though and get one locally. Thanks, Roy
Roy
Old 08-27-2006, 02:40 PM
cougar1969 cougar1969 is offline
cougar1969 Driving a Ford
Why do you need a 4 bolt main block? 429/460 blocks are strong engine blocks and unless you are going to be making some ungodly amount of HP you don't need 4 bolt mains. For most Street and race applications 2 bolt mains are more than sufficiant.
Randy
Old 08-27-2006, 02:42 PM
CutawayAl CutawayAl is offline
CutawayAl Driving a Ford
If you want to get a block locally it would help your search if you let people here know where you are.
Old 08-27-2006, 04:35 PM
gregaust gregaust is offline
gregaust Driving a Ford
Most common is to use a 2 bolt and use an ARP main stud kit.There are main girdles also but i 've never used one
Old 08-28-2006, 08:35 AM
dfree383
Guest
Posts: n/a
You don't really need the 4 bolt mains untill you start getting in the 800 hp range. The 2 bolt blocks a really strong and pretty inexpensive.
Unless you can find 4 bolt one really cheap I wouldn't waste the time.
Old 08-28-2006, 05:30 PM
Phantasea466's Avatar
Phantasea466 Phantasea466 is offline
Phantasea466 Driving a Ford
And if you MUST have a 4-bolt block you always have the option of installing a set of aftermarket 4-bolt main caps in a 2-bolt block..........
Damon Sea
1983 Mustang
534ci
"If it doesn't fit, Force it. If it breaks then it needed to be replaced anyway"
http://photobucket.com/albums/f75/Phantasea466
  #7
Old 08-28-2006, 08:02 PM
I really don't think I'll be tapping 800 horses, I just thought that it would be worth looking for one over the next year to build for future use. I live in Oregon and there are lots of good cars up here in the Northwest. I was just hoping to learn how to identify a 4 bolt main block so I could look for one. They can't be quite as hard to find as the Holy Grail Is there some distinguishing marks on the outside of the blocks that identify it as a 4 bolt block, or do you just have to start looking under oilpans??? Thanks, Roy
Roy
  #8
Old 08-28-2006, 11:15 PM
Chuck Stevens's Avatar
Chuck Stevens Chuck Stevens is offline
Chuck Stevens Driving a Ford
The only way to know for sure is to drop her drawers.
Some people can break a cannon ball, in a sand box, with their bare hands.
  #9
Old 08-29-2006, 12:50 AM
ByronRACE ByronRACE is offline
ByronRACE Driving a Ford
Default Some you could skip maybe...
I think you could skip any blocks that Are D1xx or later...I don't believe any of those (except for one weird one perhaps) have ever been found with 4-bolt mains.
I think they're all D0xx and earlier blocks that have the potential.
And, what's your time worth? If you're hell-bent on 4-bolt mains, buy main caps and do this:
That's a common D1VE narrow-rail with Blue Thunder caps on 2,3,4 and supposedly will hold 1000fwhp.
www.RaceSystems.com
Home of Project Ludicrous Speed
  #10
Old 08-29-2006, 12:56 AM
BBBob_M's Avatar
BBBob_M BBBob_M is offline
BBBob_M Driving a Ford
Yes they are almost as hard to find as the holy grail. You will not find one in a wrecking yard. If you do... nab me some CJ heads while you're at it. Better buy a couple lottery tickets also. :wink:
Bob Meyer
www.BIGBLOCKFOX.com
'69 Mach1 390 4-spd, '64 Falcon Futura
