1978 460 Cylinder and distributor layout - 460 Ford Forum
Old 09-26-2006, 11:06 AM
shopkins shopkins is offline
shopkins Driving a Ford
Default 1978 460 Cylinder and distributor layout
A groundhog took out my F250. He chewed up the spark plug wires. So basically I have an engine with distributor and have no idea what post on the distributor goes to what cylinder. Does anyone know the following:
1. Cylinder number layout of the engine if I am looking at it from the front of the truck with the fan blade against my chest.
2. Cylinder number layout of the distributor.
Thanks,
Sam
Old 09-26-2006, 11:25 AM
pedal2themetal45 pedal2themetal45 is offline
pedal2themetal45 Driving a Ford
here ya go
http://www.boxwrench.net/specs/ford_429-514.htm
Tim
61 Comet W/200
http://i82.photobucket.com/albums/j2...al45/comet.jpg
64 International 4dr. truck w/466
http://i82.photobucket.com/albums/j2...al45/truck.jpg
Danny Cabral's Avatar
Danny Cabral Danny Cabral is offline
Danny Cabral Driving a Ford
Default firing order
Turn #1 cylinder to TDC (read on harmonic balancer) on the compression stroke (when air is forced out spark plug hole), remove ignition cap and look at which cap terminal the rotor is pointing to (this is #1 terminal on cap).
http://boxwrench.net/specs/ford_429-514.htm
May God's Grace Bless You
'78 BRONCO: 508" stroker, TFS heads, Dominator MPFI & DIS, cold air induction, dual 3" exhaust/Magnaflow mufflers, 100HP progressive dry direct-port NOS, A/C, Lentech Strip Terminator wide-ratio AOD, 3:1 Atlas II, modified Dana 44/60-lockers-4.10s, hydroboost/4-disc brakes, ram-assist/heim joint steering, Cage long radius arms, custom traction bars, 4" lift, 35" mud tires
Old 09-26-2006, 11:34 AM
Default THANKS!
Thanks Guys
Old 09-26-2006, 04:04 PM
ScottJackson ScottJackson is offline
ScottJackson Driving a Ford
I like how that picture is of a chevy block. It's the correct ford cylinder numbering, just thought it a bit funny that they used a cheby block for the actual pic.
