Timing an unknown cam engine - 460 Ford Forum
Old 10-28-2006, 04:53 PM
BBPERFORMANCE BBPERFORMANCE is offline
BBPERFORMANCE Driving a Ford
Default Timing an unknown cam engine
I bought a 1979 truck with a 460 it has an aftermarket cam but I have no idea what it is , HOW can I time the engine without causing problems
When you think your ready, Check everything One more time, Then Double check your work.
Error equation: 5 min = 5 hours
Old 10-28-2006, 05:25 PM
ByronRACE ByronRACE is offline
ByronRACE Driving a Ford
Default Ignition timing?
Are you talking about ignition timing? If so, you set ignition timing like any other engine...start small, work your way up. 15ish initial, 25ish total, work your way up listening critically detonation under load.
If you're talking about cam timing, you can make some assumptions and just time it straight-up; or you could measure it with a dial indicator and make some judgements that way.
www.RaceSystems.com
Home of Project Ludicrous Speed
Old 10-28-2006, 06:57 PM
Yes Ignition timing, so 15* advance?
Old 10-28-2006, 07:01 PM
Another Issue !!! The distributor cap is labeled with a #1 and the wire goes to cyl #5 (Right front when facing engine) is it poss that they changed the firing order with the cam they put in it?
Old 10-28-2006, 07:34 PM
The standard firing order is 1,5,4,2,6,3,7,8 according to the dist cap marking it is firing 5,4,2,6,3,7,8,1 ??
Any Insight on this??
When I use the timing light on either # 1 or # 5 cyl the readings are off the chart
Old 10-28-2006, 07:43 PM
That is the firing order for a Non Ford Block,
But It IS a ford 460
  #7
Old 10-28-2006, 08:08 PM
forestg forestg is offline
forestg Driving a Ford
Somebody installed the distributor one cylinder off and was too lazy to correct it. They just moved the wires over one terminal all the way around.
Forest
  #8
Old 10-29-2006, 12:45 PM
The Mad Porter's Avatar
The Mad Porter The Mad Porter is offline
The Mad Porter First On Race Day
Default The one thing not mentioned here is...
...proper distributor curve.
For most mild 460 combos with D3 heads and low compression 14 to 16 degrees intitial and 34 to 38 degrees total in by 2800 to 3 k RPM works quite nicely.
As suggested in another post start conservatively and sneak up on it.
Here is a link to my website with instructions for recurving the ford duraspark distributor. This is very important for best performance and economy. The factory curve is emissions oriented and the aftermarket remanned distributors are hit and miss so far as the curve is concerned.
http://www.reincarnation-automotive....ons_index.html
8)
"EMC 2006" 3rd place finisher
Custom ground cams
Customized crate engines
http://R-H-P.biz
"ReinCarNation High Performance" (253)-988-6648
http://www.facebook.com/SMJRHP#!/SMJRHP
  #9
Old 10-30-2006, 07:09 PM
If the dist. was improperly installed then I should still be able to use cyl 1 for timing. isnt that correct?
Insurance
Date of Birth
Month Day Year
Privacy
