Rollerizing a C6 - 460 Ford Forum
Old 01-01-2007, 12:50 PM
Frank Merkl's Avatar
Frank Merkl Frank Merkl is offline
Frank Merkl Driving a Ford
Default Rollerizing a C6
# 9 brg is ford part#E6DZ -7G178-A or timken # FH-58073
#7&8 are GM# 9436851 and the one for the front planetery is Ford # F81Z-7A166-AA
Changing any of the other thrust washers will not help as they are not loaded or shouldn't be .
# 9 -shorten the oneway race to 1.010"
#8- machine the rear hub to fit the O.D of brg & I.D .050" smaller thanI.D.of brg .050" deep, machine back side of rear planetary .030" deep x.050" larger than O.D. of brg
# 7-machine the frt side of the planetary .040" deep same o.d. of the brg ( the brg is .140" thick & the stock thrust washer is .062", most C6's have way to much endplay , you want to have between .030-.045 end play when done , the orginal thrust washer race on the sungear shell can be removed to get the other .040" clearance here if neccesary)
# 5 Front planetrary already has 2 factory torringtons all you have to change there is the one thrust washer , the planetary needs the snout turned down .010" approx for I.D. of brg to fit (planetary's vary here)then machine face .040" deep x .050" larger than the O.D. of the brg , on the forward ring gear hub machine a groove .058" deep the same O.D. as the brg and .050"smaller than the I.D( Note the .050" on theses is for oil inlet clearance)
All cut should be done with a good carbide cut as the pins that are being trimmed are tool steel
Any Questions email me at fmerkl@eidnet.org
Pics http://www.putfile.com/pic.php?img=4392074
http://www.putfile.com/pic.php?img=4392073
http://www.putfile.com/pic.php?img=4392072
http://www.putfile.com/pic.php?img=4392071
http://www.putfile.com/pic.php?img=4392070
Sorry about the delay in sending
Frank Merkl
Old 01-10-2007, 10:52 PM
Darrin Gorham Darrin Gorham is offline
Darrin Gorham Driving a Ford
Default c4
Frank, have you ever rollerized a c4?
Old 01-12-2007, 04:31 AM
gregaust gregaust is offline
gregaust Driving a Ford
Darrin
C4 is easy done.Have a look over on fordmuscle .com in the sticky posts in the C4 forum and the instuctions i posted are there.
Old 09-20-2007, 11:45 AM
bmp for tyler
Old 09-20-2007, 09:24 PM
Gearhead559's Avatar
Gearhead559 Gearhead559 is offline
Gearhead559 Driving a Ford
Send a message via AIM to Gearhead559 Send a message via Yahoo to Gearhead559
hey i needed this...was just asking about this! thanks frank!
The heartbeat stops here!
I bleed blue oval blue, and **** hugger orange!
www.gearheadzautomotive.com
http://i5.photobucket.com/albums/y19...sigpiccopy.jpg
Old 09-21-2007, 07:54 AM
DaveMcLain DaveMcLain is offline
DaveMcLain Driving a Ford
On the C6 when you roller-ize the planetary gears do you machine the stock sprag race in the back or do you substitute one from another trans, E40D?
This looks EXACTLY like what's been done to Noelke's C6's that he uses in his monster truck and it's never caused any problems at all in that application. What about the front planetary set having 3 gears is that really ok for a high horsepower application? At least two of his transmissions are like that 4 gears in the low gear set, 3 in 2nd.
Thanks for the pictures.
Any sufficiently advanced technology is indistinguishable from magic --Arthur C. Clarke
Dave McLain
McLain's Automotive
  #7
Old 09-21-2007, 09:36 PM
Dave ,I machine the stock sprag race, and the 3pinion planetery's are plenty strong , I've never seen one hurt ,now on the low ratio gear sets it's a different story I've seen the planetary's explode but I've yet to see a stock ratio planertary ever hurt
Frank
  #8
Old 09-21-2007, 09:43 PM
that good to know!!!! keep the info coming!
ill be starting on building my c-6 hopefully soon!
  #9
Old 09-22-2007, 08:44 AM
I do think Noelke broke a set of planetaries in one of his transmissions one time, I think it was the front set and it tore out the splines. It only happened one time so it was an isolated problem. I think the only hard parts he's ever broken have been an input shaft, a set of planetaries and a few converter sprags.
The C6 parts are amazingly strong!
Dave McLain
McLain's Automotive
  #10
Old 11-15-2007, 01:01 AM
bmp
ph dozent stop ringging
  #11
Old 01-13-2008, 04:34 PM
Thunderchild Thunderchild is offline
Thunderchild Driving a Ford
Is the advantage of rollerizing to reduce frictional loss and/or improve strength? Reduced friction loss seems like the obvious answer. However, I know little about powertrain which is why I ask.
Joe
1999 Cobra Vert SOLD
1970 Lincoln Continental Mark III GONE
Protect your hobby. Join the SEMA Action Network ===> www.SEMASAN.COM
  #12
Old 01-13-2008, 06:04 PM
You got it :wink:
  #13
Old 06-30-2009, 01:39 PM
r1ckyb0nd r1ckyb0nd is offline
r1ckyb0nd Driving a Ford
bringing back an old post I know.
Frank,
Can you please repost the pictures as the links do not work anymore.
Thank you
  #14
Old 07-01-2009, 03:03 AM
Frank,
Thank you
Rick if it is any help PM me your direct email i can send the pics and info direct i have all saved in a word file..
  #15
Old 07-03-2009, 09:21 AM
f250_mike's Avatar
f250_mike f250_mike is offline
f250_mike Driving a Ford
Here is some pics Frank sent me a few years back.
I hope these are what your looking for.
mike
Insurance
Date of Birth
Month Day Year
Privacy
