78 79 4x4 headers - 460 Ford Forum
Old 03-03-2007, 04:29 PM
DAWG DAWG is offline
DAWG Driving a Ford
Default 78 79 4x4 headers
has any one ever used L&L swap headers before i hear they make good stuff getting my stuff together to swap my 400m out of my truck putting a 429pi in
67 S CODE FAST BACK 454 FE , 84 CAPRI 460 C/6 78 F150 4X4 400M 4SPEED GRT DIRT LATE MODEL 89 SALEEN#128 67 FAIRLANE 427 CLONE
Old 03-03-2007, 04:35 PM
385s fox body 385s fox body is offline
385s fox body Driving a Ford
just get the outside frame header and theres no problem, the in frame have lots of clearence issues, so I have heard
I put 460s in every thing that can hold them, and some that can't
Old 03-03-2007, 04:50 PM
norm norm is offline
norm Driving a Ford
the l&l's are a real nice header.the fenderwell headers eliminate some problems but the exhaust will have to dump in front of the rear tires unless you run it back under and then inside the frame ,then you could run tailpipes.the chassis exit headers are a little close to the front drive shaft.
the l&l's have nice thick flanges and are probably one of the highest quality headers you can get.the only problem is they are only 1 3/4" primary ,but if you are only running a 429 that should be ok.
Old 03-03-2007, 05:03 PM
DAWG Driving a Ford
i heard the in frame were close do you have to do any cutting on the fender well or anything on the out side frame rail style
Old 03-03-2007, 05:16 PM
norm Driving a Ford
you have to cut the inner fenders a little.when i had the l&l's thats all i had to do i think.i have hedmans now and had to clear on the drivers side frame/body mount.i don't thinkthe l&l's collector is that far back so shouldn't be a problem.
Old 03-03-2007, 06:10 PM
F350 Strait F350 Strait is offline
F350 Strait Driving a Ford
I am using L&L headers on my 79 F350 however it's not a 4X4. Mine are a chassis exit and I had no problems installing or running the exhaust. Their lifetime warranty is nice too.
  #7
Old 03-03-2007, 06:15 PM
norm Driving a Ford
it's the front drive shaft and the transfer case that get in the way with chassis exit headers.a 2wheeler won't have these issues.
  #8
Old 03-03-2007, 06:23 PM
Greenbroncoguy's Avatar
Greenbroncoguy Greenbroncoguy is offline
Greenbroncoguy A Ford God!Greenbroncoguy A Ford God!Greenbroncoguy A Ford God!Greenbroncoguy A Ford God!Greenbroncoguy A Ford God!Greenbroncoguy A Ford God!Greenbroncoguy A Ford God!Greenbroncoguy A Ford God!Greenbroncoguy A Ford God!Greenbroncoguy A Ford God!Greenbroncoguy A Ford God!
Send a message via Yahoo to Greenbroncoguy
depending on the amount of lift you have the driveshaft may or may not be an issue. The worst thing in my experience about the chassis exit headers is that the passenger side collector dumps right infront of the transmission crossmember, and this makes it kind of hard to route an exhaust pipe between the transmission and the passenger side frame rail, although this may only be an issue if you have 3" exhaust.
You shouldn;t have to do anything to get the fenderexit headers to fit IIRC, but I do know having a body lift makes it alot easier to get them installed but it is not necessary.
Also excellent quality on the L&L's as well.
-Matt
-Matt
  #9
Old 03-05-2007, 01:44 PM
muddwhumper muddwhumper is offline
muddwhumper Driving a Ford
Default I think they are money well spent
I have had 3 vehicles with headers. 2 Chevorlets and my 77 F-250 4X4. I have had nothing but headaches with the 2 chevy headers--loosening bolts, blowing gaskets, etc. but I haven't had a single problem from the L&L headers--still on the original gaskets after 3 years. I love them. I don't remember how much they were b/c I bought them with the whole swap kit (bought the kit b/c I wanted to keep the 4 speed with the 460) It has been in a 77 high boy that has hit its share of mudholes and they haven't failed me yet. I highly recommend them. I don't know much about cars (mostly maintenence items) but the header flanges on them must be 3/4 inch thick--I swear.
  #10
Old 03-05-2007, 01:46 PM
I bought the ones that exit inside the chassis and have had no problems with running exhaust. I have a divorced transfer case.
  #11
Old 03-05-2007, 02:38 PM
Danny Cabral's Avatar
Danny Cabral Danny Cabral is offline
Danny Cabral Driving a Ford
I love my L&L Products Ultra Flow headers. They fit great and the electroless nickel plating has a lifetime warranty. I've had them for eight years, on two vehicles and they look great (watch the footnotes).
http://www.landlproducts.com/ultraflowmain.htm
http://www.landlproducts.com/ultraflowBronco.htm
Some other options:
FPA (Ford Powertrain Applications) for '78-'79 Bronco:
http://www.fordpowertrain.com/FPAindex/FPA%20index1.htm
http://www.fordpowertrain.com/FPAindex/headers1.htm
Heddman Headers for '78-'79 Bronco:
http://www.hedman.com/pages/RACING/s...-ford.html#4WD
http://www.hedman.com/pages/footnotes.html
http://www.hedman.com/pages/hedmanmain.html
Stan's Headers for '78-'79 Bronco:
http://www.stans-headers.com/ford_headers.htm
http://www.stans-headers.com/headers.htm
L&L Products Ultra Flow Headers for '78-'79 Bronco:
Hooker Headers for '78-'79 Bronco:
http://www.holley.com/division/Hooker.asp#46
http://www.holley.com/types/Super%20...ine%20swap.asp
Headers By ED for '78-'79 Bronco:
https://www.headersbyed.com/
https://www.headersbyed.com/moreinfo.htm#Header_Catalog (call for Ford Truck headers)
Mad Dog Headers for '78-79 Bronco:
http://www.geocities.com/maddogheaders/
http://broncograveyard.com/bronco/i-...rwell_exit.htm
May God's Grace Bless You
'78 BRONCO: 508" stroker, TFS heads, Dominator MPFI & DIS, cold air induction, dual 3" exhaust/Magnaflow mufflers, 100HP progressive dry direct-port NOS, A/C, Lentech Strip Terminator wide-ratio AOD, 3:1 Atlas II, modified Dana 44/60-lockers-4.10s, hydroboost/4-disc brakes, ram-assist/heim joint steering, Cage long radius arms, custom traction bars, 4" lift, 35" mud tires
  #12
Old 03-05-2007, 02:45 PM
Default brinell - flanges
http://www.network54.com/Forum/85220...luminum+heads-
  #13
Old 03-06-2007, 10:24 PM
superduty79 superduty79 is offline
superduty79 Driving a Ford
I got my hookers runnin through the crossmember and theres 3inch from the the collector to the mufflers, littlle mods ,but they work......lift has nothing to do with it..
  #14
Old 03-07-2007, 08:43 AM
actually a body lift gives you more room to work, but regardless there is no way I would want my exhaust that close to my transmission- it generates enough heat by itself...
-Matt
  #15
Old 03-08-2007, 08:02 AM
prosandguy's Avatar
prosandguy prosandguy is offline
prosandguy Driving a Ford
I will second with Matt on that one, no reason to bring more heat into that area if not neccesary. I have the Heddman fenderwell headers on my bronco and I love them. They clear everything fine, just took about 1/4" off the front body mount to give a little more clearance. My dad had a '79 bronco with a 429, Hooker inside the frame headers, those things were crap. Even with a 4" lift it would rub on the front driveshaft once in a while, and with a rear sump pan, the drain plug was right on top of the collector, made oil changes a mess. Could never get that bronco to run cool either.
Big Broncos for life!
Insurance
Date of Birth
Month Day Year
Privacy
