460 REAR FREEZE PLUG - 460 Ford Forum
Old 04-05-2007, 10:15 AM
TCRUSH TCRUSH is offline
TCRUSH Driving a Ford
Default 460 REAR FREEZE PLUG
I finally got my block back from the machine shop.I'm getting ready to install the freeze plugs and I have a question on the rear plug.I have the how to build a big block ford book and i swear it says to install the plug with the cup side in.I thought you would install it the same way as the other freeze plugs.Do you bottom out the freeze plug,or does it need to be a certain distance in?Thanks for any help.
Old 04-05-2007, 12:13 PM
pedal2themetal45 pedal2themetal45 is offline
pedal2themetal45 Driving a Ford
I don't think you bottom it out they it would be blocking the passage.. You would bring it flush with the out side of the block I would think..anyway thats the way I've seen them..
tim
61 Comet W/200
http://i82.photobucket.com/albums/j2...al45/comet.jpg
64 International 4dr. truck w/466
http://i82.photobucket.com/albums/j2...al45/truck.jpg
Old 04-07-2007, 11:28 AM
BOSS 429's Avatar
BOSS 429 BOSS 429 is offline
BOSS 429 Driving a Ford
from the fact the bottom went in, but..we always install the cup side in, to many aftermarket cams have rubed the cup when put in the other way,plus it lets a little more oil back there,,,, so install cup in,and push till even with block face, done.....
RICH
CIRCLE (R) 815 712 8738
CLYINDER HEAD PORTING
COMPLETE ENGINES
632 557 532 598CI ETC
READY TO RUN OR DYNOED
Old 04-09-2007, 12:55 PM
Thanks for the help.Thats how I will install it.I was surprised on how many people never heard of installing it that way.
Old 04-09-2007, 01:59 PM
Danny Cabral's Avatar
Danny Cabral Danny Cabral is offline
Danny Cabral Driving a Ford
Default cam core plug
Originally Posted by BOSS 429
from the fact the bottom went in, but..we always install the cup side in, to many aftermarket cams have rubbed the cup when put in the other way,plus it lets a little more oil back there,,,, so install cup in,and push till even with block face, done.....
The above statement is incorrect. I, personally, have never had a camshaft contact a correctly installed core plug, nor have I seen or used an 'expansion plug' (as opposed to a 'cup plug') on a 429/460 engine.
A 'cup type' core plug is designed to be installed with the flanged edge facing outward (toward flexplate). This is because the maximum diameter of a cup plug is at the outer (sealing) edge/lip of the flange. It's imperative to install a cup plug into it's machined bore using the proper tool; it's not meant to be installed with a tool that contacts the flange. A cup plug is correctly installed when the flanged edge/lip is just beyond the chamfered edge of the bore/tunnel.
Conversely, an 'expansion type' core plug is designed to be installed with the flanged edge facing inward (toward camshaft). This is because the maximum diameter of an expansion plug is at the base/bend of the flange (with the flange flaring inward). It's also imperative to install an expansion plug into it's machined bore using the proper tool; it's not meant to be installed with a flat tool that contacts the crowned portion of the plug. The tool should push on the outer circumference of the expansion plug during installation. An expansion plug is correctly installed when the maximum diameter of the plug is just beyond the chamfered edge of the bore/tunnel.
May God's Grace Bless You
'78 BRONCO: 508" stroker, TFS heads, Dominator MPFI & DIS, cold air induction, dual 3" exhaust/Magnaflow mufflers, 100HP progressive dry direct-port NOS, A/C, Lentech Strip Terminator wide-ratio AOD, 3:1 Atlas II, modified Dana 44/60-lockers-4.10s, hydroboost/4-disc brakes, ram-assist/heim joint steering, Cage long radius arms, custom traction bars, 4" lift, 35" mud tires
Old 04-09-2007, 02:33 PM
63boxtop 63boxtop is offline
63boxtop Driving a Ford
nicely put danny, the only ford engine that i could think of that goes the other way is the FE engine from all the pictures i've seen
  #7
Old 04-10-2007, 11:32 AM
Thanks guys.I'm confused.The book says one way,but I have always installed them like a regular freeze plug.I should of looked at it before I removed it from the block.
  #8
Old 04-10-2007, 12:54 PM
mod4x4 mod4x4 is offline
mod4x4 Driving a Ford
The replacement cam plug that comes with the Clevite and Pioneer core plug set is a reverse taper plug, which is designed to be installed flat side out like an FE.
  #9
Old 04-11-2007, 02:19 PM
I have a Federal Mogul brass freeze plug kit.How do you guys think I should install the cam plug?Their is two ways and I'm not sure what to do.I have a early 70's d1VE block.Thanks
  #10
Old 04-11-2007, 02:41 PM
PBR PBR is offline
PBR Driving a Ford
Send a message via AIM to PBR
Not sure it will you out or not TCRUSH but my D1 block has the plug flat side in - freeze plug style.
** EDITED to avoid confusion **
Changed cup to flat, realized everyone may not think of the cup lip being away from the block as cup side in.
-Paul
  #11
Old 04-11-2007, 07:23 PM
rmcomprandy Bleeding Blue
I have NEVER seen a 385 series cam plug with reverse taper, (as with the FE cam plug which actually says RT on the plug). Of course I use Ford Motor Company cam plugs so, they may have them somewhere but, I've yet to see one, ever since Ford started manufacturing this engine.
Install the flat part of the 2 1/2" plug IN with the edge OUT.
EDIT: changed the mis-typed 2 1/5" plug to read 2 1/2".
www.rmcompetition.com
CUSTOM ground camshafts
CNC porting
  #12
Old 04-11-2007, 07:35 PM
Lem Evans Lem Evans is offline
Lem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue Path
Right or wrong , I install the cam plug with the "flat side" in ....with red loctite . We can get the plug in too far and preload the cam retainer at the front ...just do a trial fit to make sure the plug is not in too far in .
B F Evans Race Parts
270-278-2376
  #13
Old 04-12-2007, 04:58 AM
Install the flat part of the 2 1/5" plug IN with the edge OUT.
Thank you Randy and Lem.
Originally Posted by TCRUSH
Thanks guys. I'm confused. The book says one way,but I have always installed them like a regular freeze plug. I should of looked at it before I removed it from the block.
What book?
Why can't you look at your "removed" core plug?
Look at the new core plug...which way is the flange tapered?
Is the edge of the flange larger (typical cup type core plug) or smaller (expansion type core plug) in diameter than the flat side?
I have a Federal Mogul brass freeze plug kit. How do you guys think I should install the cam plug? Their is two ways and I'm not sure what to do.
It's not a matter of choice.
There is only one correct way to install a 'cup type' core plug!
There is only one correct way to install an 'expansion type' core plug!
  #14
Old 04-12-2007, 08:06 AM
83-88T-Bird Guy's Avatar
83-88T-Bird Guy 83-88T-Bird Guy is offline
Forum Contributor
83-88T-Bird Guy Driving a Ford
I installed mine flat side in. The biggest question I had when I put it in was how far in does it go?? I started reading this post and started to get nervous that I had put it in backwards.
Thanks Danny, Lem and Randy for clarifying. Pics would be great at showing how far to insert. (if anyone has any) Alan
Alan Mackin
83 T-Bird 460
83 T-Bird Heritage 5.0 RHO
84 T-Bird 5.0
87 T-Bird Turbo Coupe 460
95 Mustang GT 5spd Saphire Blue (purple)
95 Mustang GT auto Saphire Blue (purple)
  #15
Old 04-12-2007, 10:12 AM
The answer:
