Bronze thrust plate with iron cam - 460 Ford Forum
Old 04-07-2007, 12:29 PM
Steve Vardion Steve Vardion is offline
Steve Vardion Driving a Ford
Default Bronze thrust plate with iron cam
Does anybody know if its OK to use bronze thrust plate with a cast iron cam? My guess is tht this is OK but can anybody verify this?
Thanks Steve
Old 04-07-2007, 01:53 PM
Danny Cabral's Avatar
Danny Cabral Danny Cabral is offline
Danny Cabral Driving a Ford
Default Re: Bronze thrust plate with iron cam
Originally Posted by Steve Vardion
Does anybody know if its OK to use bronze thrust plate with a cast iron cam? My guess is that this is OK but can anybody verify this? Thanks Steve
Yes, that's OK. Actually, a bronze cam thrust plate can be used with either cast iron or steel camshafts.
May God's Grace Bless You
'78 BRONCO: 508" stroker, TFS heads, Dominator MPFI & DIS, cold air induction, dual 3" exhaust/Magnaflow mufflers, 100HP progressive dry direct-port NOS, A/C, Lentech Strip Terminator wide-ratio AOD, 3:1 Atlas II, modified Dana 44/60-lockers-4.10s, hydroboost/4-disc brakes, ram-assist/heim joint steering, Cage long radius arms, custom traction bars, 4" lift, 35" mud tires
