TFS Street vs. Edelbrock Performer vs. Pro Comp alum. heads. - 460 Ford Forum
Old 07-31-2007, 11:19 PM
c.evans c.evans is offline
c.evans Driving a Ford
Default TFS Street vs. Edelbrock Performer vs. Pro Comp alum. heads.
Guys,
There has been a lot of discussion lately on the Forum about which head is the best. Some of it has been heated discussion, and some of it has already been discussed and debated before. The newcomers probally should learn to use the search function and they'll find a lot of answers to their questions. One question was, has anybody done back to back dyno tests comparing them. I know that we haven't, and we don't really plan to. However, I have had the opportunity to port and flow test both the Edelbrock heads and the TFS Street heads. I don't ever plan to port any Pro Comp heads, because other engine builders and porters whom I respect, have already said that they are at the bottom of the pecking order, so I'll believe them.
The data I'm about to give you, may help you because these flow numbers are ALL from our bench, using the same slider plate fixture, same bore size, same radius entry, and other criteria etc. So hopefully that does away with advertising hype and bench differences.
Edelbrock Performers 2.19 X 1.75 valves
1. Unported, out of the box;
Intakes;
.100=66, .200=135, .300=202, .400=253, .500=296, .600=316, .700=327, .750=333 cfm.
Exhausts; (without a test pipe)
.100=58, .200=106, .300=144, .400=171, .500=187, .600=200, .700=205, .750=207 cfm
2. Fully ported Edelbrocks (by me)
Intakes;
.100=67, .200=138, .300=204, .400=260, .500=309, .600=334, .700=347, .750=354 cfm.
.100=57, .200=114, .300=158, .400=189, .500=216, .600=230, .700=241, .750=243 cfm.
TFS Streets 2.200 X 1.750 valves
Intakes;
.100=67, .200=144, .300=211, .400=275, .500=325, .600=351, .700=351, .750=352 cfm.
.100=51, .200=100, .300=138, .400=169, .500=194, .600=211, 700=223, .750=227 cfm
2. Fully ported TFS Streets (by me)
Intakes;
.100=70, .200=153, .300=231, .400=295, .500=335, .600=358, .700=367, .750=370 cfm.
.100=58, .200=110, .300=154, .400=187, .500=219, .600=240, .700=251, .750=256 cfm.
I hope this data helps you make your own decision. I do not want to get into a heated debate about which head is better, this, that or the other. I will say, that if you have a mild street engine, pump gas, hydraulic cam and etc., that it's not going to make much of a difference which heads you run. On the other hand, if you have a hot street/strip engine, bigger cubic inches or a race engine, then is when I think the differences will show up.
Hope this helps,
Charlie Evans
Old 07-31-2007, 11:26 PM
ThndrChkn's Avatar
ThndrChkn ThndrChkn is offline
ThndrChkn Driving a Ford
Thanks Charlie..... :wink:
Doug... 8)
[SIGPIC][/SIGPIC] '86 F150... 521 w/ FRPP SCJ Heads, Glide...
Best ET: 1/8---6.17 @ 112 mph N/A @ 1200'
6.34 @ 112 mph N/A @ 5000'
1/4---9.73 @ 136 mph N/A @ 1200'
9.97 @ 135 mph N/A @ 5000'
Old 08-01-2007, 04:22 AM
robert_h robert_h is offline
robert_h Driving a Ford
Thanks, good info.
Sorry for a noob question; these Edelbrocks are the 'smaller' ones with the OTB 292 cc intake port volume?
Old 08-01-2007, 09:31 AM
dfree383
Guest
Posts: n/a
Charlie, Thanks for posting the Info.
Old 08-01-2007, 09:42 AM
Phantasea466's Avatar
Phantasea466 Phantasea466 is offline
Phantasea466 Driving a Ford
Ditto.......
Damon Sea
1983 Mustang
534ci
"If it doesn't fit, Force it. If it breaks then it needed to be replaced anyway"
http://photobucket.com/albums/f75/Phantasea466
Old 08-01-2007, 09:44 AM
bruno's Avatar
bruno bruno is offline
bruno Driving a Ford
any info on the scj performers that is what i have on my car-- they were also ported and cnc !!the intake tracks were also reshaped for a straiter shot to the chambers
  #7
Old 08-01-2007, 09:47 AM
Bruno,
Look in the engine build section for the Head Information Thread. All of the data is there, A TON of information :idea:
Edit:
Heres some interesting information for ya'
http://460ford.com/viewtopic.php?t=4300&highlight=heads
Damon Sea
1983 Mustang
534ci
  #8
Old 08-01-2007, 09:51 AM
jones's Avatar
jones jones is offline
jones Driving a Ford
Awsome info!
  #9
Old 08-01-2007, 10:17 AM
1959Ford 1959Ford is offline
1959Ford Driving a Ford
Thanks for the great information Charlie.
  #10
Old 08-01-2007, 10:34 AM
CarsByCarl's Avatar
CarsByCarl CarsByCarl is online now
CarsByCarl Driving a Ford
Thanks Charlie. Way to step away from the drama and get back on topic.
Big Block Ford High Perfomance
Stoker kits, engines, cams, carbs, exhaust, and more
Owned and operated by a BBF owner/operator
  #11
Old 08-01-2007, 10:48 AM
rmcomprandy rmcomprandy is online now
rmcomprandy Bleeding Blue
robert_h,
The regular "Performer" heads are the smaller ones.
I don't know about what Charlie does with the flange openings but, when I fully port these D0VE size intake ports I automaticly open them to a VICTOR port match; (not full CJ size). Just so you know, it doesn't change the airflow very much.
It seems that most people running fully ported heads go this route.
www.rmcompetition.com
CUSTOM ground camshafts
CNC porting
  #12
Old 08-01-2007, 12:45 PM
Thanks!
I get confused how E'brock (or companies selling them) sometime call the heads Performer RPM/Vic Jr and 460CJ.
//Robert
  #13
Old 08-01-2007, 04:39 PM
Originally Posted by rmcomprandy
robert_h,
I agree with Randy and did the same thing to those Edelbrock heads, because the owner was running a Victor manifold. I have a template of a unmolested Victor that we match the heads to. On many of the TFS Street heads we do the same thing also.
Hope this helps,
Charlie Evans
You may not post new threads
You may not post replies
Powered by vBulletin® Copyright ©2000 - 2013, vBulletin Solutions, Inc.
