| The Auction Block Buy, Sell, Trade your parts and pieces!! |
For Sale 460 PI. D1VE block, D2OE-AB heads. Std bore with factory forged dish pistons. Crank is .010/.010. CJ style rods with new ARP 2000 bolts. New rings, bearings, oil pump, cam, lifters, springs, retainers, locks, Ferrea valves(2.25/1.76). No porting on heads. New Lunati solid cam 41606(247/255 @ .050, 568/580). Fel-Pro head gaskets. Stealth intake. Fox body oil pan, Hooker headers and fox body mounts. Holley 850 dp(been sitting). Have a front motor plate and ATI adapter for GM trans(used). Engine is assembled. $2200 for all. Will not seperate unless someone wants just the engine.
ADDED- parts to go with the engine FOR THE SAME PRICE: Ohio H-beams(used but good), used forged flat top pistons(std same as motor), used head studs, used Motorsports alum valve covers, pulleys(stock) NEW PRICE $1800 FOR ENGINE AND ALL PARTS For Sale 86 Mustang Gt. White with Gray GT interior. 8 pt cage and welded subframe connectors by Mid-South Racecars. All factory interior in good shape. No rust in car. Has a pin on cowl hood(new, never mounted) and the factory hood. Paint is fair to good on car but the black part of the factory hood is checked. Car is NOT cut up or mini tubbed. 8.8 rearend with 3.55 gears. 5 hole on back and 4 hole on front. Manual brake conversion. Comes with Southside lowers and tubular upper rear end control arms. It has p/s but comes with a manual rack. GOOD TITLE $2900. NEW PRICE $2600 FOR CAR $4100 FOR EVERYTHING ADDED- have a stock C-6 that was working and a new in box TCI manual valve body(not installed) that can go with either the car or the engine AT THE SAME PRICE. Don Jonesboro, AR (870) 926-8483 |
| Sponsored Links | |
Advertisement | |
#2
ADDED- parts to go with the engine: Ohio H-beams(used but good), used forged flat top pistons(std same as motor), used head studs, used Motorsports alum valve covers, pulleys(stock)
ADDED- have a stock C-6 that was working and a new in box TCI manual valve body(not installed) that can go with either the car or the engine. |
NEW PRICE
$1800 for the engine and extra parts $2600 for the car $4100 for everything Call if interested (870) 926-8483 |
any pictures? Tcruse@hotmail.com Thanks
FAST CHEAP RELIABLE.....you can only pick 2! http://i68.photobucket.com/albums/i9/alotaball/sig.jpg |
| Display Modes | |
