| General Tech A place to discuss general tech regarding chassis, transmission, tires, suspension, non-460, etc |
I keep reading that flowmasters are too restrictive and lose some hp. I just bought some 40 series flowmasters for a good price and now i hear they might hold me back a little. My build is mild ~400 hp and my rpms will be below ~5000. Should I look to swap for somethig better?
stephen
Sharpen your pitchforks and light your torches... 'CHANGE' is coming! We say grace, and we say ma'am, if you ain't into that we don't give a damn... cause a country boy can survive! |
| Sponsored Links | |
Advertisement | |
#2
http://460ford.com/viewtopic.php?t=15606
May God's Grace Bless You '78 BRONCO: 508" stroker, TFS heads, Dominator EFI, DIS, A/C, Lentech Strip Terminator wide-ratio AOD, 3:1 Atlas II, max built Dana 44/60-lockers-4.10s, hydroboost/4-disc brakes, ram-assist/heim-flip steering, Cage long tubular radius arms, 4" lift, 35" tires |
Well I guess I should have did a little more research. They will have to do for now. Or maybe I'll just go get some 18" glasspacks!!
stephen
Hey Danny are those a chambered or straight through muffler? looking for somthing to replace the Flowmasters on the little hotrod chevy pickup I just put together (not mine, its the wife's bosses' kids truck).
Street Head Mafia 69 mustang coupe 529, glide. 9.01 @148****5.60 @ 122.11 |
I ran stock replacement mustang type 3 chamber flowmasters for years , the one with the metal heat shield and only a 2.5 biggest size and my car ran just as well with them on. I did run a 3 inch pipe and cut open to 3 inch only in the front. 2.5 out still . Last time i ran it it ran a 6.79 at 101 in the 1/8 at 75 degree afternoon though the mufflers. It ran 110mph on a 100 nx shot {125 Fwhp} though the flows and not spraying out of hole. I thought the 70 lbs of pipe and mufflers it should of picked up something. :cry: I only ran 1/8 and in the quarter they may make a big differance . ED
http://www.magnaflow.com/wideopen/wideopen.asp
#7
Danny: okay, so my flowmasters are not the very best, but since it is a smaller, milder, lower rpm engine it will not hurt as much as they did on your bigger, badder 508, right? I mean you should be "breathing" a lot heavier than I will, so "exhaling" won't be as critical.
#8
#9
okay, I found 2 magnaflow 2.5" mufflers that have less than 3000 miles on them. $50 gets them to my door. The issue is that they are not "see through" like ya'll were talikng about. They have a center inlet and offset outlet. A website I found shows that setup with a chamber like design. If that is true then what would be different than a flowmaster?
stephen
#10
#11
Well i read the same about flowmasters i been using them for years so i took off the flows and put on the dynomax ultra flos bullet 3"in and out 12" long and just like everybody said big diffrence went 10.604 @ 128.38mph verses flowmasters 10.80s @125mph and i think it would have been better than 2 tenths because that day the flairup from 1st to 2nd was crappier than ever.
#12
X2...Dynomax Ultraflows!
Nick
1966 ProStreet Fairlane: Street driven 573 BBF, 4.605 bore A460 block, ported TFS Street heads, JE pistons, Eagle rods, 4.3 SCAT crank, Bullet cam, ATI C6, 3.5" X pipe and Dynomax Ultra Flows...thanx Charlie/Lem & Jet Boat Bob! http://www.jetboatbob.com/ http://bfevansraceparts.com/ |
#14
Hey FeetFirst i havent tryed open headers against ultra flos but the guys at the track have and they say half a tenth gain at the best with open headers over ultra flows.
#15
| Display Modes | |
