c6 transmission cooler lines pressure and temp - 460 Ford Forum
Old 12-04-2007, 12:30 PM
skosler's Avatar
skosler skosler is offline
skosler Driving a Ford
Default c6 transmission cooler lines pressure and temp
I was thinking of rerouting the lines using poly tubing (press rating 120 psi @ 150 deg F) I can also get a higer one. If properly routed, would this work? It will probably be a non-permanent fix, meaning I will bend the steel tubing sometime in the future.
Sharpen your pitchforks and light your torches... 'CHANGE' is coming!
We say grace, and we say ma'am, if you ain't into that we don't give a damn... cause a country boy can survive!
Old 12-04-2007, 12:31 PM
skosler's Avatar
forgot to mention. It is on a 1979 f100 2wd and will be driven on the street, but not an everyday vehicle. It has a radiator and external air cooler.
Old 12-04-2007, 06:17 PM
Frank Merkl's Avatar
Frank Merkl Frank Merkl is offline
Frank Merkl Driving a Ford
Use steel tubing ! it's inexpensive and at any auto parts store
Frank
Old 12-04-2007, 06:32 PM
Danny Cabral's Avatar
Danny Cabral Danny Cabral is offline
Danny Cabral Driving a Ford
I've successfully used -6 AN Aeroquip stainless steel braided hose for years.
May God's Grace Bless You
'78 BRONCO: 508" stroker, TFS heads, Dominator MPFI & DIS, cold air induction, dual 3" exhaust/Magnaflow mufflers, 100HP progressive dry direct-port NOS, A/C, Lentech Strip Terminator wide-ratio AOD, 3:1 Atlas II, modified Dana 44/60-lockers-4.10s, hydroboost/4-disc brakes, ram-assist/heim joint steering, Cage long radius arms, custom traction bars, 4" lift, 35" mud tires
Old 12-04-2007, 06:53 PM
BIGDOG466's Avatar
BIGDOG466 BIGDOG466 is offline
BIGDOG466 Driving a Ford
Steel or braided or the wall!! :shock:
Old 12-04-2007, 11:06 PM
skosler's Avatar
I see your point guys, but i was wondering for a temp fix. For some reason i have some weird bends i have to make. The headers are so close to the c6 and everything else. They are supossed to fit that model. They are cheap heddman headers.
  #7
Old 12-05-2007, 02:26 AM
Broncman Broncman is offline
Broncman Driving a Ford
Parker makes a hose called Push Loc. A lot of places use it for air hose but it is actually rated for 300 PSI in the 5/16 - 3/8 " sizes. It is also rated for oil etc. We have used it for years at work for Airlines. I went to my hose supplier for some braided lines and he (a Parker dealer) asked what i was using it for. I told him transmission cooler lines and he said "use push-loc,,, it's cheaper and rated for oil and up to 300psi."
It has been on my C-4 for over 5 years . Most auto parts stores also carry transmission cooler "rubber hose" as well. I never run steel because it is such a pain to route and get flared properly. Just takes to long. I think I paid 30 bucks for a roll of 30 foot long tranny cooler hose at Advance last year also...
When in doubt, throttle out...
www.hardlineoffroad.com
  #8
Old 12-05-2007, 04:05 AM
ProStreetFairlane's Avatar
ProStreetFairlane ProStreetFairlane is offline
ProStreetFairlane Driving a Ford
Garage
Get your headers ceramic coated and use braided line.
Nick
NIGHTSHADE: 1966 ProStreet Fairlane
Street driven 573 BBF, 4.605 bore A460 block, ported TFS Street heads, JE pistons, 6.8 Eagle rods, 4.3 SCAT crank, Bullet cam, ATI C6, 3.5" X pipe and Dynomax Ultra Flows...thanx Charlie/Lem & Jet Boat Bob!
http://www.jetboatbob.com/
http://bfevansraceparts.com/
