Starting a on new build P-51 525ci - 460 Ford Forum
Go Back   460 Ford Forum > Tech Topics > Engine Build Archive
Engine Build Archive A place to archive DYNO or 1/4mile VERIFIED engine builds. Please post any engine tech questions to the Engine Tech forum.
Old 03-19-2008, 07:47 PM
69RATRAP 69RATRAP is offline
69RATRAP Driving a Ford
Default Starting a on new build P-51 525ci
Starting on my next build 525 ci IDT block with P-51 heads. I will post dyno results and track performance in future. 4.5 bore with 4.125 stroke. 14 to 1 compression with single dominator and one fogger system. Diamond pistons on GMP aluminum rods. Titan oil pump, roller cam 865 Int. 849Exh. 116 lobe sep. hopefully this build can move a 3800 lbs car down the track.
Old 03-19-2008, 07:58 PM
Lem Evans Lem Evans is online now
Lem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue PathLem Evans Walks on the Blue Path
More lift than is needed...may be more LSA even for spray at that c.i.d. .....jmo .
B F Evans Race Parts
270-278-2376
Old 03-19-2008, 08:08 PM
I posted this cause I wanted input. cam company recommend this grind and change firing order. This gross lift will be less with lash and component flex. this is what I,am told.
Old 03-26-2008, 05:25 PM
dfree383
Guest
Posts: n/a
Why the firing order change?
Old 03-27-2008, 07:40 AM
Default 525 build
The firing order is changed to 15486372 and they call it a pro stock F.O. The firing position of 8 and 2 should make the engine run smoother and probably change the choppy sound. The cam is in and they changed the size of the lift after it was ordered. I will install this cam and see how it performs. I had to draw the two F.O.s out on paper and look at the difference.
