Kaase-9 Boss mustang started today, 4/11/08, with pix, #5 - Page 3 - 460 Ford Forum
Go Back   460 Ford Forum > Tech Topics > Jon Kaase Racing Engines
Jon Kaase Racing Engines Jon Kaase is considered one of the best minds in the world of Big Block Fords and has created many parts to help enthusiasts with their 460 based projects. Gentlemen start your questions…
Photobucket
  #31
Old 04-12-2008, 07:54 PM
Nevs's Avatar
Nevs Nevs is offline
Nevs Driving a Ford
Originally Posted by JonKaase
Now, that's what I call a better idea :idea: :!:
"Perception is reality"
"Failure is not an option"
Charter member 460Ford.com "*** kissers"
2001 F150 4X4 SuperCab
2003 Harley Electra Glide Ultra Classic
1998 25.4 Mustang, 598 C head...done by fall, good Lord willing...
"No time to drive any of them"
Old 04-12-2008, 08:01 PM
JonKaase's Avatar
JonKaase JonKaase is offline
Super Moderator
JonKaase Spreads the gospal of BBFJonKaase Spreads the gospal of BBFJonKaase Spreads the gospal of BBFJonKaase Spreads the gospal of BBFJonKaase Spreads the gospal of BBFJonKaase Spreads the gospal of BBF
OK, so here's another question. What 385 motor mount application would have a stud or bolt hole on the outside? I don't want the kind that looks like a Chevy. I want something that takes up very little room. ... Jon
  #33
Old 04-12-2008, 08:03 PM
36 truck 36 truck is offline
36 truck Driving a Ford
Jon what about the L&L 460 mount for 78/79 trucks? Like the ones in this thread.
http://460ford.com/viewtopic.php?t=24274
Tom Williams
Big Block 36 Ford 1 ton truck 460 5spd
1929 Ford Model A
1972 Gran Torino Sport
1987 Thunderbird Turbo Coupe
2006 Ford Ranger
http://i204.photobucket.com/albums/b...emod4fun36.jpg
  #34
Old 04-12-2008, 08:15 PM
Chuck Chuck is offline
Chuck Driving a Ford
The tunnel in a fox car is off center, so the motor will set closer to the passenger side. It helps with the clearance of the steering shaft. Not sure about the 05 & newer. I have a set of 460 mounts into a fox, I will donate to the cause if your interested? It may give you a closer idea on engine mounts.
  #35
Old 04-12-2008, 08:17 PM
JonKaase's Avatar
Super Moderator
isn't there a stock Ford mount like this? It looks like what I had in mind. Jon
  #36
Old 04-12-2008, 08:40 PM
Jon this one is used on 86/97 F250s with a spacer plate to bolt to the engine as the motor mount only has 2 holes.
Tom Williams
1929 Ford Model A
2006 Ford Ranger
  #37
CarsByCarl's Avatar
CarsByCarl CarsByCarl is offline
CarsByCarl Driving a Ford
I might have some stock mounts from a pickup that look sort of like that. I'll take a look tomorrow.
  #38
Old 04-12-2008, 08:56 PM
cougar1969 cougar1969 is offline
cougar1969 Driving a Ford
Jon Looks great makes me want to put my Boss in my car even more...
are you going to produce the single four single plain???
Randy
  #39
Old 04-12-2008, 10:00 PM
monsterbaby monsterbaby is offline
monsterbaby Driving a Ford
Actually I prefer the stealth mounts from the performance unlimited as they appear to be stronger and everyone that I have heard of using them have better luck then the L&L, but they are a single stud and look about the same.
http://performanceunlimited.com/cust...ginemount.html
  #40
Old 04-12-2008, 11:33 PM
Yoeman's Avatar
Yoeman Yoeman is offline
Yoeman Driving a Ford
No useful info here, just a bump for what may be one of the most awesome threads ever at 460ford.com
  #41
Old 04-13-2008, 12:17 AM
Doug Rahn's Avatar
Doug Rahn Doug Rahn is offline
Doug Rahn Driving a Ford
Jon, where are the mounts on the K member in relationship to the bolt hole bosses on the block (fwd & aft)? In one photo it looks like they are close to the same center-line. A little creative fabrication and you could make something that kind of mimics the ears on the mod motor block. I'll see if I can come up with a sketch to show you what I'm talking about.
  #42
Old 04-13-2008, 06:30 AM
Doug Rahn's Avatar
Jon, here is a quick and crude concept drawing I did in my CAD program last night. But, something along these lines just might do what you need. I converted to JPEG format so I could post it.
  #43
Old 04-13-2008, 08:37 AM
Monstermiler Monstermiler is offline
Monstermiler Driving a Ford
I think these are the same mounts that Tom posted but that link is broken. The adpater plate bolts to the block, then mount bolts to adapter. This give you 2 bolts to the outside. This is what carl is refering to. They are standad on late 460 trucks. Mounts are available off the shelf from any parts store. The adpater is strictly a Ford item.
One thing the L&L and Performance Unlimted mounts have no safety strap inside of them, if they fail. The Ford mount has an interlocking strap should the rubber fail. I have split L&L and performance unlimited mounts.
Bill Bennett
Street Head Mafia Wanna Be
"Can't Never Could"
www.hillbillymotorsports.com
  #44
Old 04-13-2008, 09:39 AM
cdeal28078 cdeal28078 is offline
cdeal28078 Driving a Ford
That engine looks nice sitting in the car. If you need me to come haul off that other engine and parts I will. Wonder if the wife would let me put it in her 07 v6 Mustang? Sure would improve it.
Clint
1971 Ford F100, 460/c6
PS, PDB, Auto, 3.0 gear
  #45
Old 04-13-2008, 11:14 AM
ByronRACE ByronRACE is offline
ByronRACE Driving a Ford
Default Mounts
My old West Coast cobra uses a Lincoln passenger car mount from the 70's that I thru-bolted. They adapt to perches that are welded to the frame with a single cross-bolt. Seems to me a mount like that on the block with a custom perch wouldn't be too bad. I used two 3/8" fasteners to make the mount more or less solid in tension, but still retain the compression dampening ability. I've been happy with the result...no funny thunking or tapping and the engine doesn't move around much.
I dragged out the original mounts and took pics...
Somewhere, I have the information about where I got the new (identical, just new) mounts I used in my build. I remember it was a common aftermarket supplier (dorn?) and a 4-digit part number. I found the mounts by thumbing through a picture book that a local supplier had and found a match visually. They work great for me, and I like the simple cross-bolt installation for R&R purposes. I'm able to move the engine forward and use a temporary pin to hold it in that temporary location when the transmission needs service. Helpful.
If you need me to dig through my file cabinet, I'm sure I can find the information.
And the perch I fab'd in my frame looks like this...
Doesn't get much simpler. If that's where you want to go with it, I'll help with more info.
www.RaceSystems.com
Home of Project Ludicrous Speed
Insurance
Date of Birth
Month Day Year
Privacy
