Distributor cap Firing Order - 460 Ford Forum
Old 05-26-2008, 12:35 PM
96GTSMOKER 96GTSMOKER is offline
96GTSMOKER Driving a Ford
Default Distributor cap Firing Order
I have the Firing Order but I do not know which is number 1. Any one have a picture of the cap and what order they are in.
Old 05-26-2008, 12:56 PM
cheatham's Avatar
cheatham cheatham is online now
cheatham Driving a Ford
you can put it about where you want as long as you have number one cylinder on TDC drop the distributor in and where it seats go from there.
Typically though it should be about the 2:00 oclock position.. And on alot of caps number 1 is marked either on outside of cap or inside. Firing order is counter clockwise 15426378
Old 05-26-2008, 01:06 PM
Mine is not marked anywhere. It is popping through the carburetor. I did change the firing order he had on the truck but the number ones location I was not sure if I started in the correct spot.
Old 05-26-2008, 02:31 PM
BLACKBRONCO BLACKBRONCO is offline
BLACKBRONCO Driving a Ford
I realize that is the same firing order as the 302, is that correct?
1993 Bronco
460, performer intake,850 holley,msd 6al, b&m shifter
In my garage waiting to see some action:
Dove-C heads
Victor Intake
1.7 comp cams rockers
Crower Solid Roller cam
3500 rpm hughes converter.
Old 05-26-2008, 02:58 PM
ByronRACE ByronRACE is offline
ByronRACE Driving a Ford
Default Non-HO
Non-HO 302, yes...same.
www.RaceSystems.com
Home of Project Ludicrous Speed
