460 weight? - 460 Ford Forum
Old 10-15-2008, 06:39 PM
cadunkle cadunkle is offline
cadunkle Driving a Ford
Default 460 weight?
How much does a complete iron 460 weigh? How much weight is shaved by using aluminum heads and intake?
Also, anyone know how much a complete iron head/intake 350 Chevy weighs?
Old 10-15-2008, 07:20 PM
zephyrbob zephyrbob is offline
zephyrbob Driving a Ford
hm, i keep wondering the same thing. alum head 460 should go 680. pos chevy should go about 550.....bobn
ps anotherwords to the top lol...
scouts, and zephies rule 12.3 109 corrected using dragtimes calcul
Old 10-15-2008, 07:22 PM
Finmach's Avatar
Finmach Finmach is offline
Finmach Driving a Ford
Guys, what do you think from this? Left side weights are the std. weights which I found from the internet (can't remember from whose web-pages). Right side weights are modified only with the weight of aluminium heads, aluminium intake, aluminium waterpump and I skipped the headers because there are so many variations. This should get you in the ballbark. If there is something you disagree please let me know.
- '72 Mach 1 460 (A429+G429)+TKO600+M9" DL
- intermediate go fast project
TOTAL PERFORMANCE
Old 10-17-2008, 08:52 AM
billandlori's Avatar
billandlori billandlori is offline
billandlori Driving a Ford
The figures I have read before list a fully dressed (I guess thats pants and a shirt, etc. :shock: ) iron 460 at 720lbs.
You can reduce about 30lbs per head and 30lbs for intake. Total est weight 630lbs.
I'm sure others here have the actual numbers.
Hope this helps,
Bill
I salute our troops. Thanks for your service.
"The Key Board Warriors"
1983 Thunderbird
Big Block Power
466 Edelbrock Performer RPM heads, cam, intake
Old 10-17-2008, 11:27 AM
RCJ RCJ is offline
RCJ Driving a Ford
598 IDT block A460 heads with .250 motor plate, peterson wet/vac,elec. water pump.No carb, stater,exhaust or fluids. 636lbs on REBCO chassis scales
TFS A head, 4.5 crank from AD,ultra block, Diamond 4.600 pistons BME 6.7 rods ,peterson wet/vac ,2 3/8headers ,new styleTFS intake,jesel 1.8,287-297at.050.800 lift 112 installed 108, danny bee
Old 10-17-2008, 07:57 PM
Finmach's Avatar
Yep, there are some items missing like;
- fan blades & clutch
- flexplate or flywheel
and maybe something else, but this chart was made to compare the different engine's weights in oem condition and after aluminium head, intake, waterpump upgrade. All the aluminium parts were actually scaled, FE waterpump, Weiand aluminium 429, etc.
this is direct copy paste from the original:
Weight analysis, engine system 3.00, model year 1973, 429-4V, auto trans
SYSTEM COMPONENT WEIGHT
3,01 BASIC ENGINE SUBSYSTEM 563,04
3,02 ENGINE LUBRICATION SUBSYSTEM 26,22
3.03* ENGINE COOLING SUBSYSTEM 19,25
3,09 VALVE TRAIN SUBSYSTEM 33,56
SUB TOTAL 642,07
3,03 ENGINE COOLING (FINAL LINE)
RADIATOR 20,70
RADIATOR CAP 0,14
ENGINE COOLANT 41,00
FAN SHROUD 3,50
FAN SHROUD (ATT. PARTS) 0,16
FAN 2,67
FAN SPACER 0,40
FAN (ATT. PARTS) 0,16
HOSE & CLAMP ASSY. (UPPER) 0,92
HOSE & CLAMP ASSY. (LOWER) 1,15
SUB TOTAL 70,80
3.04# CARBURATION & AIR CLEANER NA
3,05 ACCESSORY DRIVE SUBSYSTEM
ALTERNATOR BRACKETS 1,12
ALTERNATOR ADJ. ARM 0,59
ALTERNATOR BRKT. (ATT. PARTS) 0,59
CRANKSHAFT PULLEY 4,70
WATERPUMP PULLEY 2,79
BELT- ALT. BELT 0,19
BELT- P/S DRIVE 0,33
BELT- A/C DRIVE
BELT- THERMACTOR
SUB TOTAL 10,31
3.06# STARTER SUBSYSTEM NA
3.07# IGNITION SUBSYSTEM NA
3,08 EMISSION
THERMACTOR
SPARK CONTROL
NOx CONTROL 3,00
VAL. ASSY-C/C VENT + PTS 0,95
SUB TOTAL 3,95
TOTAL 727,13
* ONLY THOSE ITEMS THAT ARE PART OF THE BASIC ENGINE
# NOT ENGINE & FOUNDRY RELEASE RESPONSIBILITY
TOTAL PERFORMANCE
  #7
Old 10-19-2008, 09:47 PM
57custom's Avatar
57custom 57custom is offline
57custom Driving a Ford
I weoghed mine before I installed it in my fairlane. Here is the stats.545 cid, aluminum super cobra jet heads, victor intake 1050 dominator, stock dist, flex plate, large starter, aluminum water pump,aluminum valve covers. weighed it on my old farm scale as I call it. It is accurate I checked with my weight on another scale. 576 lbs It is now a bit lighter I think, as I have added a meziere water pump and a small geared starter. :shock:
63 Fairlane 500 tudor sedan 10.44/131 so far thru the mufflers. 10.29 with open exhaust. Update 10.20 at 132 open axhaust
  #8
Old 10-19-2008, 10:33 PM
thanks, thats lighter than i figured...good news...bobn
  #9
Old 10-19-2008, 10:34 PM
Larry T's Avatar
Larry T Larry T is offline
Larry T Driving a Ford
at work on our certified scales my 71 model 460 block weighed 220lbs.
  #10
Old 10-20-2008, 07:09 PM
nuclearcobra's Avatar
nuclearcobra nuclearcobra is offline
Forum Contributor
nuclearcobra Driving a Ford
iron stock 429-460 =640lbs www.fordcobraengines.com/engineweights
  #11
Old 10-23-2008, 02:41 PM
Torque Torque is offline
Torque Driving a Ford
Default iron headed sbc weighs
Sbc chevys w/ iron heads typically weigh around 525lbs
