my slow 521 build - 460 Ford Forum
Go Back   460 Ford Forum > Tech Topics > Engine Build Archive
Engine Build Archive A place to archive DYNO or 1/4mile VERIFIED engine builds. Please post any engine tech questions to the Engine Tech forum.
Old 11-03-2008, 04:35 PM
bbstang502's Avatar
bbstang502 bbstang502 is offline
bbstang502 Driving a Ford
Default my slow 521 build
1995 gt mustang
521 -4.300 stroke
4.390 bore .005 in the hole
6.800 rod
1050 4500 quick fuel
victor 4500 intake
tfs streets ported by me 73cc chamber
22cc dish probe pistons 10.85 -10.9 compression
MPG windage tray
hooker headers 2 inch primarys 3 1/2 collector with 3 1/2 bullets
35 degrees total timming
28-10.5 mt slicks
3.70 gears
c6 trans with brake
ptc 5000 converter
car pnds 3536 with driver -----------
cam ,268 In. 279 Ex. @.050
.738 .722 lift on 110 lobe sep installed@ 106
E.T. 9.88 to 9.94 1/4 mile depending on 60 foot
1/8 mile is 6.28 to 6.35 witha 1.37 60 foot
200 shot spray in the 1/8 E.T. is 5.84 -5.90 witha 1.31 -1.32 60 foot depending or traction and wheel stands
Old 11-03-2008, 04:46 PM
bruno's Avatar
bruno bruno is offline
bruno Driving a Ford
great numbers man ---- you have a heavy car --- superb numbers 8)
[SIGPIC][/SIGPIC]
www.bfevansraceparts.com
www.evansracingengines.com
JET BOAT BOB
DAN "STICKER MAN" HOBBS
Old 11-04-2008, 11:06 AM
69fb 69fb is offline
69fb Driving a Ford
Did you install longer valves in teh heads? I seem to remember the max lift being .680 on the streets.
What was your mph?
1969 Mustang Fastback - stock 1968 460 with carb/intake/cam/headers - 12.12 @ 112 on 17" drag radials
Old 11-04-2008, 12:47 PM
bbstang502's Avatar
What was your mph?
using the valves that came in the heads, i just used the correct springs . i dont know the miles an hour , the mph at the track has not been working for about 4 months. they clame they cant get the part to fix it, they said they will have to buy a whole new system .
Old 11-05-2008, 12:20 PM
NITROUS FORD's Avatar
NITROUS FORD NITROUS FORD is offline
NITROUS FORD Driving a Ford
Send a message via Yahoo to NITROUS FORD
Default SOUNDS REALY GOOD!
What was your mph?
WHAT IS YOUR RPM AT THE TRAPS! :roll: :roll:
Old 11-05-2008, 01:43 PM
bbstang502's Avatar
Default Re: SOUNDS REALY GOOD!
What was your mph?
6800-6900
  #7
Old 11-05-2008, 07:32 PM
dtimmer's Avatar
dtimmer dtimmer is offline
dtimmer Driving a Ford
so approx 138-140? wow
-Derik
Visner Engine Development, LLC
616-726-6600
  #8
Old 11-06-2008, 08:12 AM
bbstang502's Avatar
My guess would be like 135 -136
  #9
Old 11-11-2008, 07:28 AM
busta busta is offline
busta Driving a Ford
Can someone work out a rough horsepower figure from those numbers posted?
My new combo shall be quite similiar, but im using Blue Thunder heads and im hoping for more like 850 aspirated engine hp.
  #10
Old 11-11-2008, 07:36 AM
dfree383 dfree383 is offline
dfree383 Driving a Ford
Need the actual weight of the car, but assuming about 3000# it would be in the 600-650 range to run those times.
  #11
Old 11-11-2008, 08:47 AM
Bruno said he had a heavy car.
Anyone know what it is and what it weighs?
Damn you guys think 3500lb is heavy. My coupe will weigh in at around 4000lb :shock:
  #12
Old 11-11-2008, 09:09 AM
bruno's Avatar
my car weights in at 3300 w/ me in it --- i referenced mine as being heavy alot of the guys on the board have fox chassis that weight in under 3000 w/ the driver ....thats all
[SIGPIC][/SIGPIC]
JET BOAT BOB
  #13
Old 11-11-2008, 01:54 PM
bbstang502's Avatar
my car is 3536 with driver
  #14
Old 11-11-2008, 01:59 PM
Your probably in the 650-700ish Range, also alot depends on your chassis set up and how well everything is working together. the Calculators are only Approximate.
  #15
Old 11-11-2008, 06:06 PM
Perhaps the owner can had it dynoed and can chime in with a figure. :lol:
Insurance
Date of Birth
Month Day Year
Privacy
