4x4 super duty front end "clunk / rattle" - 460 Ford Forum
Old 01-29-2009, 02:12 PM
prostockpat prostockpat is offline
prostockpat Driving a Ford
Default 4x4 super duty front end "clunk / rattle"
i have a 2001, 4x4, v10, crew cab ,super duty.texas truck.i have changed upper/lower ball joints,shocks,sway bar links,tie rod ends.
i still can not get rid of the clunk i hear and feel when hitting even small bumps.i`ve drove newer s.d. and it`s not as bad,but seem to have it too.
i can` t be the only one to have this problem ?? any help ??
thanks.
'79 Ford NTPA 4x4 pulling truck
648 cid {Bes/Tony Bishoff}
11.2 C&C alum. block
Thor gen 2 heads{Charlie Evans}
Billet crank
Grp rods
Ross pistons
Comp cam
Military front,Rockwell rear
Crower triple disc clutch
Pitbull rear,Cepek front
"RAT TRAP"
Old 01-29-2009, 02:31 PM
tubais tubais is online now
tubais Driving a Ford
curious if it goes away when its in 4wd?
Old 01-29-2009, 02:41 PM
steves4570 steves4570 is offline
steves4570 Driving a Ford
Send a message via AIM to steves4570 Send a message via MSN to steves4570 Send a message via Yahoo to steves4570
Default noise
ck thr spring instalaters on top of springs they are not hard to install and may be your noise.Also ck bolts from trans crossmember to front of truck. steve
Old 01-29-2009, 03:22 PM
A70Maverick A70Maverick is offline
A70Maverick Driving a Ford
Replace the sway bar bushings on the front axle that hold the bar itself to the axle with the clamps. That should fix it. Did hundreds when I was at the dealership. I think there were two bar diameter options also, have the build date/VIN of your truck handy when you buy 'em!
557ci 70 Maverick, 8.76@153 1.25 60ft.... So far....
Old 01-29-2009, 04:02 PM
mguy's Avatar
mguy mguy is offline
mguy Driving a Ford
I just rebuilt the suspension on my 97 T-bird, and I noticed a rattle over bumps. Turned out to be the disc brakes. One of the bolts wasn't seated right because of crud that I apparently missed, but also, the anti-rattle spring wasn't doing its job. I'd check what everyone else says, and if not that, check the brakes.
The Original "RedneckProfessor"
Old 01-29-2009, 04:17 PM
zephyrbob zephyrbob is offline
zephyrbob Driving a Ford
my super duty recently put me in the ditch. with the return of the straight axle versus the cv joint front ends i neglected to grease the front u joint. pisses me off. i know better as a diehard jeep/scout guy.
....the ujoint locked up, stop me from turning the steering wheel, blew out the stub axle and locking hub.....fwiw bobn
scouts, and zephies rule 12.3 109 corrected using dragtimes calcul
  #7
Old 01-30-2009, 01:41 PM
fordmonsta86 fordmonsta86 is offline
fordmonsta86 Driving a Ford
check the shock mounts, had a 91 that did the same thing, ended up being that the bolt had eatent the sleeve that goes through the rubber in the mount on the shock itself
  #8
Old 01-30-2009, 10:22 PM
f250_mike's Avatar
f250_mike f250_mike is offline
f250_mike Driving a Ford
My 95 f250 4x4 had a clunk in the front. It turned out to be the lower shock bolts. Ford used metric bolts (12mm I think) and the shock sleeve was 1/2".
I fixed it by drilling the mounts and using 1/2" bolts.
  #9
Old 02-01-2009, 10:04 AM
Brian F Brian F is offline
Brian F Driving a Ford
Is there a "Track Bar", Really a panhard bar- that locates the front end. Dodges have one and they are notorious noise makers.. They don't last long either, the bushings . My cummins truck, 04', does that, I ignore it too!!! :?
3 '66 Galaxies is a sickness
Q code Baby!
Edel Headed 466, Crites Hood&Headers, Tremec TKO600, 3.25 TracLock
  #10
Old 02-01-2009, 12:21 PM
WileyCoyote WileyCoyote is offline
WileyCoyote Driving a Ford
Default Clunk
My 2001 had a clunk because the leaf springs did not slide against each other properly. The dealer first removed the plastic spacers between the leaves which did not help.
The only way I could get rid of the clunk was to lubricate the leaves where they rubbed together. Pry the leaves apart where they contact each other and pump in some chassis grease where ever they are rubbing together. This is an easy way to check if it is noisy rub as the noise will go away immediately.
I guess Ford forgot how to make leaf springs.
This would only work for a short while and then they would start making noise again.
Hope this helps,
Harry
Half of being smart is knowing what you're dumb at.
