Old 01-31-2009, 03:05 PM
1Bad65's Avatar
1Bad65 1Bad65 is offline
1Bad65 is an unknown quantity at this point
Default MID-PLATE opinions Please
I'd like to get some personal opinions on a MID-PLATE and there ultimate purpose. Please give some reasoning behind your opinion if you can. Also, and at what point do you think they are necessary and would you need one if your running a front plate?
Old 01-31-2009, 10:48 PM
g334's Avatar
g334 g334 is offline
g334
Default Re: MID-PLATE opinions Please
mid-motor plates are designed to work in conjunction with front motor plates to eliminate torsional stress within the chassis. installation of the mid-motor plate also allows easier transmission swaps and aligns the drivetrain to eliminate block twisting and broken transmission cases.
if your making enough power or going through the trouble to fab a front-plate, why wouldnt you also set-up a mid-plate? :?: jmo
Old 01-31-2009, 11:04 PM
1Bad65's Avatar
Not sure exactly, Thats why I wanted opinions.
Old 02-01-2009, 05:25 PM
FACracr FACracr is offline
FACracr
Send a message via Yahoo to FACracr
I was thinking about this too. My galaxie has really low frame rails and I would have to run a massive mid plate.
Can you run a front plate with motor mounts and some type of rear limiter?
dunno
Old 02-01-2009, 06:00 PM
richter69's Avatar
richter69 richter69 is offline
richter69 is an unknown quantity at this point
If your not going to run a midplate then use the regular motor mounts. With the motor mounts there really is no need for a front plate, that is if they are solid and or you have a travel liniter.
A midplate properly installed will distribute power to the chassis more effectivly and stiffen the chassis. Motor plates can take stress off of the block where the mounts bolt up, in extreme cases a thin block and a lot of power you can get some distrortion.
Street Head Mafia
69 mustang coupe
529, glide.
9.01 @148****5.60 @ 122.11
Old 02-01-2009, 07:08 PM
notch 501's Avatar
notch 501 notch 501 is offline
notch 501
im not running a mid plate. with a front plate...running 600 hp 585 tork and foot braking it.....last season i did about 30 runs everything is fine so far may add some kind of arms if i get nervous .....
90 Mustang 501 11.04 125 mph pump gas
  #7
Old 02-01-2009, 11:18 PM
1Bad65's Avatar
I've seen the samething, just never knew about the whole deal. Some say you should run a solid trans mount with it as well.??
  #8
Old 02-02-2009, 05:02 AM
D.I.L.L.I.G.A.S.'s Avatar
D.I.L.L.I.G.A.S. D.I.L.L.I.G.A.S. is offline
D.I.L.L.I.G.A.S. is on a distinguished road
Never run an auto trans with a solid tail shaft mount in a door car, regardless of how the motor is mounted. Some kind of a flexible trans mount should always be used.
D.I.L.L.I.G.A.S. Dave::
460 street '66 Ranchero.......................finished someday.
460 race '70 Maverick..........................finished someday.
All 'glass Top Sportsman '69 Mustang......ummm, check back when I win big
playing the Texas Lotto, or online poker.
  #9
Old 02-02-2009, 06:32 PM
TopSportsman916's Avatar
TopSportsman916 TopSportsman916 is offline
Forum Contributor
TopSportsman916
IMHO, if it is an all out race car then I would use 1/4" aluminum engine plate & 1/4" aluminum mid plate. I would also buy a good poly mount for the transmission.
Chris
VPRC 1998 Mustang
557 CJ :1.15 60', 5.32@129.58 mph @ 2600lbs
665 C&C Hemi : To Be Determined
  #10
Old 02-02-2009, 08:47 PM
KAILUAZ's Avatar
KAILUAZ KAILUAZ is offline
KAILUAZ
Are the front and mid plates used just on drag cars? I'm building a roadrace/auto-x car and was wondering if I should just stick with motor mounts.
Thoughts as I'm a bit confused also?
  #11
Old 02-02-2009, 09:11 PM
richter69's Avatar
front and midplates would be fine and a better solution. And yes never use a solid tranny mount.
Street Head Mafia
69 mustang coupe
529, glide.
  #12
Old 02-02-2009, 10:13 PM
1Bad65's Avatar
Lets say you have an issue with header clearance and you want to just run a front plate and motor mounts. Would that be over kill because of the motor mounts? And would the front plate even need to be used with motor mounts?
  #13
Old 02-03-2009, 07:15 AM
ProStreetFairlane's Avatar
ProStreetFairlane ProStreetFairlane is offline
ProStreetFairlane
If you are running motor mounts then there is really no reason to run a front motor plate. Running a front motor plate does make more room for headers. I am running a front and mid plate on my Fairlane as well as a tranny mount (NOT solid).
Nick
1966 ProStreet Fairlane:
Street driven 573 BBF, 4.605 bore A460 block, ported TFS Street heads, JE pistons, Eagle rods, 4.3 SCAT crank, Bullet cam, ATI C6, 3.5" X pipe and Dynomax Ultra Flows...thanx Charlie/Lem & Jet Boat Bob!
http://www.jetboatbob.com/
http://bfevansraceparts.com/
  #14
Old 02-03-2009, 10:43 AM
Dr's Wife Racing's Avatar
Dr's Wife Racing Dr's Wife Racing is offline
Dr's Wife Racing
Default mid plate
They covered it all. It takes some time to fabricate and they can be a pain ,but if installed correctly you will have a better working car that does not break as many parts. They are worth the effort if you plan to make any kind of power or have a car that leaves hard. Ward
514 fox body 10.5 tire car
  #15
Old 02-03-2009, 11:56 AM
1Bad65's Avatar
I see. I wish I had more room for headers around my mid-plate. I made my mid plate as small as I could without it being considered not worth using. Any ideas? It's a 65 mustang with a Rod and custom coilover suspension. Towers are gone.
You may not post new threads
You may not post replies
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
