| General Tech A place to discuss general tech regarding chassis, transmission, tires, suspension, non-460, etc |
Anyone have any experience with a radiator setup like this?
With the 460 I'm trying to think of ways to lighten up the front end. I have a MKIII fan and I'm thinking of running an electric water pump (or one of these bad boys: http://www.daviescraig.com.au/main/display.asp?pid=47) Thoughts? These are the only two pictures I could find on the subject: ![]() ![]() Found another one, 03 Cobra I think:
| Sponsored Links | |
Advertisement | |
#2
Some folks I know run a Willy's nostalgia car with the rad in the trunk. Its a SBC with a blower through the hood. They had good success with it. It was only a drag car, I'm not sure how long it would keep the engine cool due to the lack of air flow.
A rad full of water weighs quite a bit, getting that weight moved back sounds like a good idea. Bill
I salute our troops. Thanks for your service. "The Key Board Warriors" 1983 Thunderbird Big Block Power ![]() 466 Edelbrock Performer RPM heads, cam, intake |
wow, ive never seen anything like that. how much hose would you need? and what would you use, braided or something else? that is very interesting.
BBF IDT SHORT BLOCK 18bolt TFS A460 heads CNC'D by SVRE TFS Intake ported (SVRE) COMPCAM by BLAKE http://i287.photobucket.com/albums/l...dressed020.jpg |
its very common for mud trucks to use rear mounted radiators so I think it would fine for 1/4 mile passes.
Most use 1 1/2" or 1 3/4" copper pipe with radiator hose to make the bends. |
per NHRA the radiator cant be in the trunk. That said I see a bunch of the heads up guys with large water tanks in the rear instead of a radiator. They use a big pump to circulate water to the front, and actually they just circulate ice water through the heads. It works very well, but those guys also have a lot of time between rounds, I doubt it would work good on a bracket car, alky maybe, but still.
Street Head Mafia 69 mustang coupe 529, glide. 9.01 @148****5.60 @ 122.11 |
A while back when I first started mounting a new 'glass body on a friends car he wanted to put the radiator in the back to make room up front. But after he realized how much extra weight would be added to the car from the extra long water lines & associated extra water volume in the long lines he changed his mind (thank god).
D.I.L.L.I.G.A.S. Dave:: 460 street '66 Ranchero.......................finished someday. 460 race '70 Maverick..........................finished someday. All 'glass Top Sportsman '69 Mustang......ummm, check back when I win big playing the Texas Lotto, or online poker.
#7
This was the other reason I decided against it, a 5 gallon water tank and all the hose was gonna add a good bit of weight to the car. The cars with the tanks I spoke of also run those big Prochargers that use the reverse mounted belt drive deal so there is no room for the radiator anyway........
#8
I was thinking about putting a radiator in the bed of my 61 F100 Unibody truck. Either in the floor or in the tailgate. I'd think some PVC or thin galvanized conduit would work for plumbing...Or get fancy and run it through some existing frame connectors or framerail tubing.
Bob Meyer www.BIGBLOCKFOX.com . . www.FordifiedRacing.com '69 390 4-spd Mach1, '61 F100 Unibody, '85 GT ragtop, |
#9
Ok, for those who live by the rules this setup is out.
Here is a hot rod breaking all the rules, this is what I'm talking about: ![]() ![]()
#11
Now THAT is cool!
#12
No liquid except fuel and water for the intercooler behind the firewall? What about the guys with dry sump oil systems that put the big tank in the trunk? The rule book does state that the radiator must be located in the stock location.
Joe But it's a dry heat! Last edited by AZFairlane; 02-15-2009 at 09:14 PM. |
#13
section 4- general regulations.
engine:1 1:1 cooling system All cooling systems/radiators must be installed in the stock location for body style used...............yada yada yada. This was my 08 rulebook as it was handy, I'm sure the 09 is the same.
#14
Here are some of the threads I've found for your reading pleasure (some of them not so much):
http://www.race-dezert.com/forum/showthread.php?t=55215 http://www.race-dezert.com/forum/showthread.php?t=53325 http://www.race-dezert.com/forum/showthread.php?t=51347 http://www.race-dezert.com/forum/showthread.php?t=39560 http://www.race-dezert.com/forum/showthread.php?t=22562 http://www.race-dezert.com/forum/showthread.php?t=14509 Also look through these builds as there are a lot of photos of different setups for radiator plumbing. http://www.race-dezert.com/forum/forumdisplay.php?f=27 |
#15
Again these are all desert trucks and such, per NHRA a "radiator" is not legal to mount in the rear. A "water tank" is.
This is a unit I took a pic of when I was up at MDRC last week, they use this for the intercooler and the heads, they even use a bilge pump and lid from a boat.
| Display Modes | |
