429 cj overdrive transmission possible??? - 460 Ford Forum
Old 02-25-2009, 07:52 AM
Tangerine1968 Tangerine1968 is offline
Tangerine1968 First On Race Day
Default 429 cj overdrive transmission possible???
Hey guys, I have a 1968 fastback and have a 429 CJ to put in it and I am wanting to get info on my transmission options. I have a c6 but would really like overdrive(if possible)-I have been told that there were some big block vans and trucks that had transmissions that would work. Any input at all would be appreciated-especially if someone here has tackled this before-
Old 02-25-2009, 08:04 AM
dfree383 dfree383 is offline
dfree383 Driving a Ford
One could make it work, but as I recall the transmissions your refering to are hugh.
Old 02-25-2009, 08:12 AM
cstmwgn cstmwgn is offline
cstmwgn Driving a Ford
There are several options depending on your budget and desires.
You can build a AOD on steriods that should handle what a "normal" 429CJ puts out. Try some searches as there are a couple very good posts on how to do this from Danny Cabrel.
You can bolt on a GearVendors to your C-6 and pull a motorhome with your 429CJ.
You can go to T56 or TKO600 if you want a "man pedal" option.
You could go E4OD (or equivelent) but you would need to make a TON of room in the tunnel for it.
G. Allen Pearson
Old 02-25-2009, 08:32 AM
bonfire bonfire is offline
bonfire Driving a Ford
lentech makes an adaptor for an AOD to the BBF he may also have an option where he cuts off the original aod bell housing and install a BBF bellhousing. $$$$ either way
I with the Government and I'm here to help
Old 02-25-2009, 09:19 AM
36 truck 36 truck is offline
36 truck Driving a Ford
Here's the article on putting an aod behind a 460.
http://www.ford-trucks.com/article/i...rd_Bronco.html
Tom Williams
Big Block 36 Ford 1 ton truck 460 5spd
1929 Ford Model A
1972 Gran Torino Sport
1987 Thunderbird Turbo Coupe
2006 Ford Ranger
http://i204.photobucket.com/albums/b...emod4fun36.jpg
Old 02-25-2009, 09:28 AM
capri476 capri476 is offline
capri476 Driving a Ford
I have an E4OD in my Mustang that I love . It is a little larger and is about six inches longer but will fit if you have the desire. Drops my highway cruise from almost 3500 rpm with the C6 and a 3500 stall to about 2500 rpm.
Gary.
  #7
Old 02-25-2009, 04:20 PM
Default Thanks
Thanks for the responses guys, I just went to the machine shop and got the ball rolling on the machine work so now I can decide which way to go on the transmission. I am (like most people) on a budget but I want it done right and am not the most tech savvy so I see I have some research to do. Any more suggestions or direction even would be cool-Thanks again
  #8
Old 02-25-2009, 09:26 PM
Diggindeeper's Avatar
Diggindeeper Diggindeeper is offline
Diggindeeper First On Race Day
you can also run a gear vendors behind the C6
  #9
Old 02-25-2009, 10:37 PM
Mark Miller Mark Miller is offline
Mark Miller Driving a Ford
Performance Automatic 301-963-8078 just released news saying they have AOD's for 429-460's and FE engines.Comes with lifetime warranty i seen this information on the N.M.R.A website,hope this info helps.
Later Mark.
Insurance
Date of Birth
Month Day Year
Privacy
