| General Tech A place to discuss general tech regarding chassis, transmission, tires, suspension, non-460, etc |
have a 95 mustang with a 521 cid engine and a 4 inch cowl hood and the hood is not open in the back like other cowl hoods , does anyone think cutting the back out of the hood would help any. thanks
| Sponsored Links | |
Advertisement | |
#2
Yup. Should help both breathing AND cooling.
The older I get, the smarter Dad was. |
It'll help drop under hood temps as well as enable the carb to draw in a cooler air charge.
The bottom of your windshield is a low pressure area. If you ever unfortunately drove it in the rain you'd see the water droplets run down your cowl hood scoop and then curve around and enter the opening at the rear like they are being sucked in.
1969 Mach 1 "Jezebel" 545ci 12:1 solid roller w/ P-51's 11.3's na, 10.3 on 150hp nos at 7200 DA |
i cut six 2 1/2 inch holes in the back and i can feel lots heat comming out. i always figured the carb.was drawing in a lot of underhood heat. i hope this helps thanks
Yes,Start cutting. It will help tremendously
(LIL TWEETY) BBF 62 Falcon Tube Chassis Member of a BAND OF BROTHERS Thanks to my sponsors for 2010 Pro Motion Machining Perfect Reflections Photography Bronx Corner Automotive |
Yes. My bad. Low pressure area between the ears.
| Display Modes | |
