| Register | Garage | Photo Gallery | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Auto Escrow | Auto Loans |
| General Tech A place to discuss general tech regarding chassis, transmission, tires, suspension, non-460, etc |
I know they are not rated for continuous duty, but will I be okay with a small load (3-5amps)? I'm thinking about running a separate solenoid as a switched leg. Any idea what's the max amount of amps I could get away with? If any?
| Sponsored Links | ||
Advertisement | ||
#2
It's not the amps across the switched legs that limit the duty cycle of a starter solenoid, it's the heat buildup in the pull-in coil that is the problem.
So, just energizing a starter solenoid for more than a few minutes would toast it, regardless of the load. The good news is that there are 30-40 amp relays available for less than 10 bucks. Greg
In Limbo at all times |
you can get continuous duty solenoid's if you choose or as stated you can just use a relay, make sure you know which is the N/O contacts and which is the N/C, and Coil. That could screw a guy up, as sometimes they're hard to read on certain relays. also make sure you grab the right coil voltage...12V i assume in your case.. sometimes they're 24V or 120V depending on where you get them.
Despite what you've heard, opportunity does not knock |
Many electric golf carts use "continuous duty" solenoids.
Some people can break a cannon ball, in a sand box, with their bare hands. |
Anyone have a part number for a relay I Can pick up at autozone or the like.
These are what I use...
http://www.oreillyauto.com/EW3/Displ...ycleCount=1672
Travellin' through time... 5.66 @ 124 8.91 @ 151 557-A429's-Glide-4.10's Last edited by Treeyasoon; 08-03-2009 at 03:55 PM. |
#7
Sounds good.
#8
i clicked the link that ws posted. and all igot was a headlight plug....
#9
Just go in and ask for a 30 amp Bosch relay. The are about 2 inches square and have 5 terminals on them. If you can find a counter person that will look, have them get you a 5 prong connector for it also, or you can just use ind spade connectors.
#10
I edited the link...they must have changed something in the system since I posted the last one.
It is item #84601. Hope this helps.-Jeff
Travellin' through time... 5.66 @ 124 8.91 @ 151 557-A429's-Glide-4.10's |
| Sponsored Links | |
Advertisement | |
| Display Modes | |
