2000 Ford Ranger Build - Page 26 - 460 Ford Forum
  #376
Old 04-06-2014, 06:27 PM
69F100's Avatar
69F100 69F100 is offline
Forum Contributor
69F100 Driving a Ford
My plans changed just a little I built me a small shop and have it where I can use it not finished but enough to work in. The frontend will be on hold until this winter I got all the big stuff for it just don't have time to cut the front out and rebuild right now. Working on getting the trans swap done right now had to order a few things and should have them by Tuesday.
Old 05-15-2014, 10:56 PM
69F100's Avatar
Forum Contributor
Transmission is in and finished now waiting for my Primer Plus to get here from Killer Ron's done some cutting to make some carb clearance for the Primer Plus plate. Trying to figure out which scoop I want to use I got a 69 Mach 1 scoop off my 69 F100 I had on it. Then I got a 4'' cowl that came off my buddy's car. I like the looks from the 69 scoop but not sure if it will help with air flow like the cowl will. I went ahead and change the windshield to Lexan.
  #378
Old 05-18-2014, 03:00 PM
butterbean butterbean is online now
butterbean First On Race Day
why don't you get one of the boss scoops from the guy that sells them on this site? I think it would look really cool!!!!!!
  #379
Old 05-18-2014, 04:34 PM
69F100's Avatar
Forum Contributor
I went with the cowl, painted yesterday should be cured to rivet on tomorrow. The way it would have to set the Boss scoop I don't think would look right it would have to be mounted so the back would be at the windshield. I got primer plus on it and windshield finished put a few rivets to hold the scoop last night.
  #380
Old 05-19-2014, 11:55 AM
69F100's Avatar
Forum Contributor
  #381
Old 05-20-2014, 11:02 PM
pepsidigger pepsidigger is offline
pepsidigger First On Race Day
Default 01 ford ranger new motor and now wont move
i just replaced the motor in my 2001 ford ranger and now it won't move (I mean it will go into gears but absolutely won't move) it is an automatic tans 4x4 i have puled the motor 3 time try to figure it out i so far i cant. I've tryed leaving the torcecoverter on, taking it out with the motor and filling it with atf didnt work, so i pulled it a 3rd time filled the tourconvertar with atf and put it back on and the installed the motor and still nothing won't move im stuck please help?
  #382
Old 05-20-2014, 11:26 PM
69F100's Avatar
Forum Contributor
Sounds to me the converter was not lock in the pump and when you bolted the engine back to the trans it busted the front pump. Sounds like the trans needs to come out and be fixed.
  #383
Old 06-01-2014, 02:22 PM
69F100's Avatar
Forum Contributor
Made it to the track for TNT last night finally all in all it was a good night the little truck is making the power for sure. Still got some chassis tuning to do but the track was slick not much prep. ran 6.41 it still has some more in it. I forgot to turn the camera on the 1st pass but here on of the 2nd it was a 6.84 pass you can see how slick the track was
https://www.youtube.com/watch?v=ed57...ature=youtu.be
  #384
Old 06-02-2014, 10:40 PM
69F100's Avatar
Forum Contributor
here the 3rd pass
https://www.youtube.com/watch?v=dpj6...ature=youtu.be
  #385
Old 06-03-2014, 02:04 AM
ricktjr ricktjr is offline
ricktjr Driving a Ford
Talking
sounds like a beast. I love it.
  #386
Old 06-04-2014, 10:51 PM
Albertcriss Albertcriss is offline
Albertcriss First On Race Day
Send a message via AIM to Albertcriss Send a message via Skype™ to Albertcriss
Nice work so far on the truck.
shimarz
  #387
Old 06-04-2014, 10:57 PM
69F100's Avatar
Forum Contributor
thanks guys
  #388
Old 06-19-2014, 09:47 AM
69F100's Avatar
Forum Contributor
Planning on some more TNT on the 27th down at SGMP it is the best track around here they prep the track good for TNT. I am going to see what it will do in the 1/4 also if I don't start getting in the rev limit at 7000 if t does I will only make 1/8 passes.
  #389
Old 06-27-2014, 10:52 PM
69F100's Avatar
Forum Contributor
New personal best 6.19 at 111 in the 1/8 and 9.79 at 138 in the 1/4
  #390
Old 06-28-2014, 09:05 AM
460VEGA's Avatar
460VEGA 460VEGA is offline
460VEGA Driving a Ford
Almost identical et as mine but more speed,there is still more in that combo for sure!
74VEGA 466 C4 6.18@110,9.77@135.66 ON PUMP GAS
