'73-'87 stock compression - 460 Ford Forum
Old 08-24-2009, 09:59 PM
79Bird466's Avatar
79Bird466 79Bird466 is offline
79Bird466 First On Race Day
Default '73-'87 stock compression
I punched the numbers into the C/R calc and got about 7.85:1. Is that about right? I have always seen the ratio listed as 8:1...is that just a rounded figure? This is for a 10.322 deck with stock D3VE (95cc) heads, 22cc dish piston and a .041 head gasket. Do all these numbers look accurate for a stock smogger?
'79 Thunderbird
466CI/C6/3.25 Traction Lok 9" Rear
D1VE block, D3VE heads, C8SE Intake & Cam, Carter AFB 625cfm carb, Duraspark II, Police oil pump, EFI timing set, 8.3:1 CR, etc...
Old 08-24-2009, 10:05 PM
Cale Aronson's Avatar
Cale Aronson Cale Aronson is offline
Administrator
Cale Aronson A Ford God!Cale Aronson A Ford God!Cale Aronson A Ford God!Cale Aronson A Ford God!Cale Aronson A Ford God!Cale Aronson A Ford God!Cale Aronson A Ford God!Cale Aronson A Ford God!Cale Aronson A Ford God!Cale Aronson A Ford God!Cale Aronson A Ford God!
72' was 8.5.1 So I think it was close....
Cale Aronson - Administrator
Black Magic Clutchs - Aronson Motorsports
Shelby Performance Mountain Motor Pro Stock Mustang
Shop - 660-646-4553 - Cell - 816-390-0852 - Email - cale@BlackMagicClutches.com
WWW.BLACKMAGICCLUTCHES.COM - WWW.GOFASTQUICK.COM
Jon Kaase Racing Engines - Ford Racing Parts - RAM Clutches - Browell - Trick Titanium - Bohr Racing - PEM Gears - Orme Brothers - Penske Racing Shocks - Innovators West - DJ Safety
Old 08-24-2009, 10:28 PM
Diggindeeper's Avatar
Diggindeeper Diggindeeper is offline
Diggindeeper First On Race Day
yeah you're likely on the right track. The compression ratio flat sucked in the smogger era for the 460.
Despite what you've heard, opportunity does not knock
Old 08-24-2009, 10:47 PM
Administrator
Scary part is in 71' they were 10.5.1!!!!!!
Sheesh!
Old 08-24-2009, 10:51 PM
79Bird466's Avatar
Did the '72s use flat tops or did the D2VE heads have smaller chambers? or neither?
'79 Thunderbird
Old 08-24-2009, 10:54 PM
Paul Kane's Avatar
Cool
Actual real world comrpession ratio for the 1973-1986 engines is about 7.7:1, and possibly less depending on actual cylinder block deck height (which varies from block to block by several thou) and acutal combustion chamber volume (which also varies).
Paul
High Flow Dynamics
  #7
Old 08-24-2009, 11:10 PM
Administrator
Paul is right.... looking at my books that is true. The 73's were about 7.5.1 in all actuallity.
Here.... this might help a little...
  #8
Old 08-24-2009, 11:23 PM
79Bird466's Avatar
I think the calculator is a bit off. I just entered the specs given from that book for a '72 460 and came up with 8.06:1. I even used the high end of the chamber size range (92.9cc) ...I'm assuming they used the same pistons as '73-'87 (-22cc)
'79 Thunderbird
  #9
Old 08-24-2009, 11:35 PM
Paul Kane's Avatar
Cool
1973-1986 heads have a chamber volume of closer to 97ccs typical, and the OEM 1973-1987 dished pistons are closer to 24cc total dish volume. Plug those numbers in and see what happens.
Paul
High Flow Dynamics
  #10
Old 08-24-2009, 11:49 PM
79Bird466's Avatar
Paul
I came up with 7.75:1 with a piston-to-deck clearance of .032 (listed in the book)
7.66:1 using .040 as a PTD clearance, which is what I have been told it is closer to.
'79 Thunderbird
