Road Racing 78 THUNDERBIRD - Page 4 - 460 Ford Forum
  #46
Old 03-06-2011, 02:00 PM
SPLUHAR SPLUHAR is offline
SPLUHAR Driving a Ford
Yes itll raise the rate & lower the car. A stiffer shock may work, but not longer. Not without careful measurements to make sure that it wouldn't bottom out the shock. What about taller bump-stops?
http://www.energysuspensionparts.com...Shock-Eyes.asp
Old 03-07-2011, 11:08 AM
Another idea.
http://www.streetsideauto.com/p/mr-g...n=PriceGrabber
Raised rate, similar or slightly higher front end height (depending on thickness vs distance between coils).
  #48
Old 03-07-2011, 03:24 PM
MauriSSSio MauriSSSio is offline
MauriSSSio Driving a Ford
Originally Posted by SPLUHAR View Post
Another idea.
that looks pretty good for what i need. Would that go BETWEEN the coils??
  #49
Old 03-07-2011, 05:36 PM
Yes.
  #50
Old 03-09-2011, 12:22 AM
bird of pray's Avatar
bird of pray bird of pray is offline
bird of pray First On Race Day
Look into Q-A1 shocks and springs for a mustang 2 style front end . Or on the least , lower the mounting point on the lower control arm if you use the vett shocks . So you can keep the lower arm as straight as possible to be level to the ground . Stock car parts stores have up to 1200 Lbs springs . About to take the rear end to the shop to put in new mounting points , disc brake mounts and new arms , and yes , I will check the pinion angle . But I'm not shure on the type of tubes on the lower arms , round or square .
  #51
Old 10-18-2011, 08:04 PM
I lost my job , and started another one . I should be able to start up again . Sorry it's taking long to get it going .
  #52
Old 06-16-2012, 11:46 PM
Default I'm sorry .
I'm putting in a different motor all together . I miss the power . A friend took me for a ride in his new modifid Zo6 , and yea , it did feel slower then any 460 I ever had , just saying . I'll do the rest of the car info at Pro-Touring .com and (heres were I lose a lot of you ) diyelectriccar.com . It will make more sence later . They do smog in Las Vegas so I can't put a 460 in my other 96 car . The car will be lighter and should be very fast . And it should cost me same to finish it . At least when I compare prices of parts .
  #53
Old 04-14-2013, 12:45 AM
Two jobs can slow down any build . but the electric motor is in an running . The whole motor and battery is the weight of the trany and fuel tank .
  #54
Old 04-19-2013, 05:55 PM
Link to build?
  #55
Old 12-19-2014, 04:56 PM
Default Just a (electric) street car .
Had to clean her up . Time an job stopped me from doing a lot . I am buying a Big Block Thunderbird , but no racing til my money is back up .
