Relocating leaf spings inward 67 mustang - 460 Ford Forum
Old 11-11-2009, 12:29 AM
460fastback's Avatar
460fastback 460fastback is offline
460fastback First On Race Day
Default Relocating leaf spings inward 67 mustang
Just wondering if anyone has ever attempted relocating the leaf springs inwards on a 60's Mustang? I need to get a little more clearance for 10.5 x 28 MT ET drags. The MT's fit, but they stick out too far for my taste. I only want to move them one inch inwards and have decided to chop away underneath. I have got one front spring pocket almost finished and am fairly pleased with the result. I have reinforced the outer sectioned frame rail with 3/16" plate and then added another 3/16 plate on the inside of the remaining frame rail side plate to make the width of the new frame rail slightly wider than the original. 3/16" plate is probably 3 or 4 times heavier than the original frame rail and the new section width will ensure that any torsion on this assembly will be handled better than the OEM design. I still need to weld in a 1" spacer outboard of the front spring eye but will wait until I have installed CalTracs to ensure pocket width is OK. Once I finish the other one, then I still need to weld new spring perches on the 9" and fab a set of 1" offset shackles. After that is done, then a little sugery on the front of the inner wheel houses and we should be good to go!
Old 11-11-2009, 09:10 PM
67mills's Avatar
67mills 67mills is offline
67mills First On Race Day
Default relocation brackets
look up mopar relocation setups,yours would be the same theory call me if you need help, a mini full tube would get you tons of room!!! 712 363 4385 Dave
Old 11-12-2009, 01:51 AM
Thanks for the offer Dave! I may just do that.
Old 11-12-2009, 09:41 AM
nickbay's Avatar
nickbay nickbay is offline
nickbay Driving a Ford
I have thought of doing this but there will not be room for tail pipes afterwards. Have you thought of moving the whole rear frame rail?
Do you have any pics with the MT 28/10.50/15's on the car and what rim size are you running? I run a MT ET street 27/10.50/15 on a 10" rim with 5.5" backspacing, with stock leaf spring location. Looks good!
67 mustang street car, 1977 460, 212 degree cam, 2500 converter, 3.50 gears, RHP Edelbrock heads
best ET 12.01, mph 112.98, 60ft 1.69
http://www.youtube.com/watch?v=7HztIgJymNw
http://s212.photobucket.com/albums/cc110/laveennick/
Insurance
Date of Birth
Month Day Year
Privacy
