460 with 390 flywheel, starter? - 460 Ford Forum
Old 01-04-2010, 06:22 AM
redfordpuller redfordpuller is offline
redfordpuller First On Race Day
Default 460 with 390 flywheel, starter?
I'm in the process of swapping out my dead C6 for an NP435 in my 77.5 F-250 4x4. I plan on buying a 390 flywheel for a 76 F-250 with a 184 tooth count and can't find any info about using a 390 starter on a 460. I'm using a 400 bellhousing with a 3/16" plate in place of the backplate to help clear my 12" clutch. I just wanted to make sure i had a starter that engaged the flywheel completly. Thanks for any help.
Old 01-04-2010, 10:27 AM
72puller's Avatar
72puller 72puller is offline
72puller Driving a Ford
460 starter will work. I have two trucks with 184 tooth flywheels and 460 starter.
Dennis
Old 01-04-2010, 12:58 PM
DaveMcLain DaveMcLain is offline
DaveMcLain Driving a Ford
We had a customer who did this and he couldn't figure out why the starter drive wouldn't last very long. I think he ended up using the 460 starter with a drive for a 390 and the 390 wheel and it worked ok, I think....
Any sufficiently advanced technology is indistinguishable from magic --Arthur C. Clarke
Dave McLain
McLain's Automotive
Old 01-04-2010, 06:52 PM
blown473 blown473 is offline
blown473 First On Race Day
Smile starter
x3 use the 460 starter. I'm using the 460 mini starter on that flywheel and it has worked flawlessly for 6 years now.
Old 01-04-2010, 07:45 PM
bbstickstang's Avatar
bbstickstang bbstickstang is offline
bbstickstang Driving a Ford
Send a message via Yahoo to bbstickstang
zoom FE 184 th wheel, lakewood can, I ended up using the late model sbf starter with the bigger registar and the 3/4" offset. good mesh both radial and longitude. the stock 460 didnt work for me because not enough tooth engagement longitude. 390 starter didnt work because the "hump" hit one of my header tubes.the late model truck starter didnt work because it didnt not engage enough either way.the lakewood can rotates the starter and changes the mesh if the starter has a non centered pinion. i put a gear reduction stater on it to help crank the 12:1 motor, a powermaster 9503 ( i think).........ron
6.15@112. 1.32/60' New best, 12-20-13 All Muscle and No Steroids!
69fb mustang ,509,nash 4+1,4.56 ,31x10.5 w ,3309 w/driver.
I get to feel the torque of a BBF 4 times an 1/8 and 5 times a 1/4.
www.classicgearjammers.org
Old 01-04-2010, 09:41 PM
rmcomprandy Bleeding Blue
Originally Posted by 72puller View Post
He must have had a 188 tooth flywheel. The starter drive for a 460 starter and one for a 360 are the same. I had problems with a 390 once and the parts store had sold me a starter for a 184 tooth and it had a 188 tooth wheel. The Mcloed flywheel on my pulling truck came with 184 teeth and is for a 460-429. I have always used a stock 460 starter on it without trouble.
Maybe they exist but, I have never in over 30 years come accross a 188 tooth flywheel with the regular automotive / light truck FE or 429/460 diameter.
150some teeth, 176 teeth, 180 teeth and 184 teeth but, never 188 of that diameter.
The McCloud / Weber flywheel dedicated for a 385 series engine is also sold by FRPP as the Z460 with a removable weight for "zero" or "counter" balanced applications and it has 176 teeth.
www.rmcompetition.com
CUSTOM ground camshafts
CNC porting
  #7
Old 01-05-2010, 04:14 AM
OldRedFord OldRedFord is offline
OldRedFord Driving a Ford
Send a message via AIM to OldRedFord
What would be the reason for using the 390 flywheel?
2002 Ford Ranger 4x4
1972 Ford F100 Sport Custom
460, C6, 9" rear, lwb
  #8
Old 01-05-2010, 08:29 AM
Mark Laczo's Avatar
Mark Laczo Mark Laczo is offline
Mark Laczo Driving a Ford
Default flywheel
Because they are easy to find, cheap, and more importantly Zero balance. In the early 90's I actually paid something like $250 for a 460 flywheel from L&L to run a heavy duty 12" clutch. On a different truck I had earlier done the 390 flywheel with a custom built 11" clutch and used a regular 400 Ford starter that usually lasts about 5-7 years and the difference in durability pulling trailers and hard farm abuse was negligible.
FWIW Mark
  #9
Old 01-05-2010, 10:11 PM
TonyS TonyS is offline
TonyS First On Race Day
Default flywheel and starter
The 390 flywheel ring is .009 inch smaller than the 460. The pitch diameter is the same. That means the teeth are exactly the same profile. What does change is the number of teeth on the ring. If you use a 390 ring you will not totally engage the teeth properly with a 460 starter. In other words, the starter will be too far away by about .005 inch. [1/2 the .009]
Will it work? Most likely. Will it work exactly right? Never. I had Kentucky Clutch balance a flywheel for me recently. I had a 1986 ext balanced flywheel that I needed to make into a neutral balance to fit a 1977 internal balance 460 that was going to replace the 1986. I had a machine shop turn the trapezoid lug off of the back of the 1986 wheel. KY Clutch then only had to drill a couple of holes to balance the wheel to 1/4 oz. If you need this kind of help, it is hard to beat this shop, their price, or their knowledge.
  #10
Old 01-06-2010, 05:45 PM
Thanks for all the help guys, i'm gonna try one of my 460 starters on it and see what it sounds like.
  #11
Old 04-22-2010, 05:29 PM
Fordman123 Fordman123 is offline
Fordman123 First On Race Day
I have a 1979 ford that had a c6 auto trans. I took it out and found a 400 bellhousing and 390 flywheel to bolt up to my 460. It works great other than my starter does not engage deep enough in the teeth. It keeps takin the outer edge of my teeth off and the flywheel is 184 tooth. Any help would be appreciated. Thanks
  #12
Old 04-22-2010, 07:12 PM
Like Dave said, use a 390 starter bendix in a 460 starter or use a 3 bolt 390 starter; (just don't use the center mounting bolt).
You could also always buy the correct flywheel from FRPP.
CNC porting
  #13
Old 04-22-2010, 09:54 PM
Fordtrucks Fordtrucks is offline
Fordtrucks Driving a Ford
I just had the machine shop ZERO balance my late model flywheel. Problem solved. No FE BS to try to make work.
93 F150 4x4 Big Block Ford Truck!
  #14
Old 04-22-2010, 11:49 PM
BOSS 429's Avatar
BOSS 429 BOSS 429 is offline
BOSS 429 Driving a Ford
ok, because if you use a 351m or 400 bell you have to use a 390 or any net ballance wheel,other wise no starter will work,a real 429 wheel is a diff od,and will not work right with a 400 bell,
as far as starters go
you can use a 351m,400,429 or 460 starter, ive done this swap about 30 or more times for people
RICH
CIRCLE (R) 815 712 8738
CLYINDER HEAD PORTING
COMPLETE ENGINES
632 557 532 598CI ETC
READY TO RUN OR DYNOED
  #15
Old 04-23-2010, 08:48 AM
A 390 FE and a 460 "automotive" flywheel are within a few THOUSANDTHS of one another on the ring gear O.D. Just the tooth count is different.
EDIT: Yes ... A production 351M/400 and production 460 use the same starter ...
CNC porting
Insurance
Date of Birth
Month Day Year
Privacy
