460 big block ranger. - 460 Ford Forum
Old 01-07-2010, 09:30 AM
93badazzlx 93badazzlx is offline
93badazzlx First On Race Day
Default 460 big block ranger.
Hey ive been kicking around the idea of a early to late 80's ford ranger 2wd regular cab short bed to put my 460/c6 in. I have a 93 forx body i was gonna do. but Due to previous owner REMOVING ALL the cars wiring. id just rather sell the shell for a couple hundred bucks and find a ranger. Ive LOOKED and googled and searched some more about the ranger swap. i didnt really come up with anything. i just finished a 302 swap in my dads lifted 88 ranger. that was actually easy. SO any and all INFO ,advice ,PICTURES, would help. like what pan can i use? what for mounts. and it looked like im gonna have to go custom headers. but will my stock cast iron manifolds work? MY 460 is out of a 78 ford/delta 25 footish motor home.
Old 01-07-2010, 09:50 AM
BigBlockRanger's Avatar
BigBlockRanger BigBlockRanger is offline
BigBlockRanger Driving a Ford
www.bigblockranger.com
'83 Mustang GT - 545/C6 - 10.46 @ 130
http://www.foureff.com
Four Eyed Fords Forum
Drag Week 2011 - 77th in Daily Driver
Drag Week 2012 - Street Race BB N/A runner-up
Drag Week 2014 - *kapooya*
Old 01-07-2010, 10:11 AM
Hey buddy. I seen the site. Is that ur truck?! thats soo cool! im staying carb.its easier for me. WHAT mounts did you use? i seen that the ones u got off ebay u thought might have sat the motor to high? did u make custom ones? and what for oil pan did you use? And your trucks a long bed isnt it
Old 01-07-2010, 10:25 AM
The mounts are BB to fox body pedestals with a 1" spacer on the driver's side. The rubber isolators were not used.
Oil pan -> truck rear sump. Same pan as used in a fox conversion.
Yes it is a long bed.
There are several guys on here with BB Rangers. Maybe they will chime in and add their swap info too.
Old 01-07-2010, 11:33 AM
501ranger 501ranger is offline
501ranger First On Race Day
The oil pan is the same "rear sump pan" that would be used in the mustang. You can use exhaust manifolds if you notch the passengerside frame rail and don't mind givining up some horsepower. Headers would have to be custom fenderwell headers. Either cut the firewall to move the engine back, or cut the radiator suport to move the radiator forward. Install traction bars or ladder bars to eliminate wheel hop. I broke two U-joints because of wheel hope and bent a leaf spring. I think a long bed truck would help with wieght distribution and handle better. I made solid motor mounts for my truck.
My 84 long bed Ranger with a 501 stroker went low 12's at 111 Mph with open exhaust manifolds, then 11.4 at 118 Mph with small tube headers. Maybe with a smaller engine the difference wont be as much. At first it had a stock shortblock 429, with a Lunati Special Purpose Solid cam, Stealth intake, Mild DOVE heads, Exhaust manifolds, 2.5" full exhaust with thrust turbo mufflers, 3.55 gears, 750 double pumper Holley, and ran 12.5's at 108mph. Now it has the pump gas 501 with Victor heads, Torquer II intake, 850 double pumper, 284 comp solid roller cam, C4 transmission, 3000 rpm convertor, 4.10 gears, 31x14.5x15 Et streets, and runs 10.57 at 124 Mph open headers and 10.62 through Magnaflow mufflers. I still drive to the track evertime I race it. I have it in the Car Build up forum if you want more details about it. http://www.460ford.com/forum/showthread.php?t=131002
Old 01-07-2010, 12:53 PM
ok so oil pan, and mounts. and ill just knock of the tranny mounts and slide it where i need it. will i need a custom driveshaft? and im not looking to modify the fire wall. and i seen on bigblockrangers site. he got an idea from this forum on how to drill and tap the oil filter house just so i can run adapters and hose. to a remote filter housing. any insite on that?
  #7
Old 01-07-2010, 12:54 PM
Oh and yea i know a long bed would be better. but this is just a street toy. and the occational pass down the 1/4. and i just like the looks of a short bed. i had a long bed 94 ranger but it was bagged and all that happy crap and i didnt like it. just looked weird to me.
  #8
Old 01-07-2010, 12:59 PM
I am using a M-6880-A50 - Ford Racing Oil Filter Adapter, that screws into block and rotates filter toward the front of engine to provide clearance for engine swaps. You will probably need a shorter driveshaft and different u-joints.
  #9
Old 01-07-2010, 03:11 PM
bigblok86ranger's Avatar
Super Moderator
On mine I moved tranny x-member brackets to the forward holes and used a truck C-6 with the ranger tranny bushing to locate the engine and trans. I used hockey pucks to get a 1 inch body lift this really made a huge difference in how the manifolds fit. I had ladder bars with coil-overs and a narrowed nine inch in the back of mine. With a mild pump gas 466 I ran consistant 12flats. There are several ways to get them in there. I moved my radiator forward on my 86 because with mine set back tight to firewall I still had 75% of the weight behind the centerline of the front axle and couldnt see it being worth the effort to mod the firewall. I had a custom driveshaft made for mine but I think it was close to stock length fox body driveshaft. I made my mounts out of left over square tubing and flat-stock.
  #10
Old 01-07-2010, 04:23 PM
you might get lucky and find one the right length at a junkyard. I did, but it really took some looking!
  #11
Old 01-07-2010, 08:39 PM
hey thanks for all the info guys. Yea like i said i have an 1978 460 wtih a c/6 out of a motorhome. the front end looked like a van. The hump of the oil pan is towards the rear. would this work? and ill search around for a oil filter location kit. ANd i do have a fox body drive shaft laying around! and im thinking of making my own motor mounts.Just dont know where to start or how to go about doing it. I got the welding skills and materials.OH and with the 1inch hockey pucks, did it make the truck look lifted? Lol. I want mine low and mean.i dont mean like scraping. but like a 12" rear tire sort of tucking in the rear.Any Pictures of home made engine mounts or there swaps to help me along? email them to Novassloss@hotmail.com. Yes nova ss loss. My first car 69 nova ss. 454 4spd.. i miss that car. thanks josh
  #12
Old 01-08-2010, 01:52 AM
Super Moderator
Here are a couple pics of mine cant really see the mounts too well but might give you some insight. The 1 inch body lift was not noticeable by most people just created some much needed clearance.
  #13
Old 01-08-2010, 01:55 AM
Super Moderator
The rear tires were 28x10.5 mt et drags on 15x10 prostars with 5.5 bs, rearend housing was 44.5 inches wide with pinion half inch offset to passenger side.
  #14
Old 01-08-2010, 07:47 AM
res0rli9 res0rli9 is online now
res0rli9 Driving a Ford
will the van pan work or dose it need to be the mustang pan. and has anybody put 460 in 4x4 ranger 86yr
  #15
Old 01-08-2010, 11:47 AM
Super Moderator
If it is the 6 quart rear sump but some had a huge 8 or 9 quart pan. As far as the 4wd ranger is concerned it will most likely need some axle swaps to solid axles if you want to do any kind of wheeling.
Insurance
Date of Birth
Month Day Year
Privacy
