my 460 won't start! - 460 Ford Forum
Old 01-18-2010, 08:47 PM
worktruck worktruck is offline
worktruck First On Race Day
Question my 460 won't start!
my '77 f250 with a 460 just will not start. All electronics are new, fuel system new, new Holly 750, and it spins like the "dickens".. Tried NAPA starting fluid and won't start. Got fuel to the carb, and about 2 hrs later tried. STARTED!. The next morning: no start!! Do I tear the carb apart or what? When it did start yesterday, it ran pretty smooth, needs some fiddling with I guess. But my main problem is, no start. Any thing I have overlooked? When it did start last year, it was stumbling and spittin' until really warmed up. Perplexed, I am. Thanks to anybody and everybody.. worktruck
Old 01-18-2010, 11:57 PM
Cambi's Avatar
Cambi Cambi is offline
Cambi First On Race Day
Which Holley 750? Vacuum Secondaries? Choke? Sounds like it needs some adjustment and perhaps the choke is not functioning.
1987 Ford F250 RCSB / 460ci / T19 4spd / Sterling 10.25"
Old 01-19-2010, 07:46 AM
digger460 digger460 is offline
digger460 Driving a Ford
Make sure you are getting spark to the plugs. Since it wouldnt start on starting fluid, maybe an intermitten electricle prob. Maybe a bad grd. Is it an MSD ign. system?
Old 01-20-2010, 12:28 PM
Retro Ranger 77's Avatar
Retro Ranger 77 Retro Ranger 77 is offline
Retro Ranger 77 Driving a Ford
I had an issue with mine where it wouldn't start when it was warmed up. Turns out the hall effect sensor in the distributor was faulty. It did have the same symptoms as yours where you could crank it continuously and it wouldn't even begin to fire, even with starter fluid. It actually started backwards once! But I did the same thing as you and replaced all of the ignition equipment and had no effect. So, if you have overlooked this component and assuming that you have the factory Duraspark II system, then this sensor could be the problem.
1977 F-250 Ranger
Built 466ci BB
*New* L&L fenderwell headers w/3" straight through sidepipes, K&N 14x5 airfilter
NP435
NP205
33" BFG A/Ts
Old 01-21-2010, 08:07 PM
RetroJim's Avatar
RetroJim RetroJim is offline
RetroJim First On Race Day
Some very good advice .
You have an electrical problem so start at the distributor and work from there . Use an ohm meter to see if you are getting power to distributor and work backward to see where the power loss is . Check the inside of the distributor and make sure everything is installed properly and nothing is loose .
Retro Ranger 77 has a good point , if the starting fluid doesn't work you have no spark .
RetroJim
Old 01-21-2010, 08:41 PM
460VEGA's Avatar
460VEGA 460VEGA is offline
460VEGA Driving a Ford
I would also check and see if the timing chain has jumped a tooth or two, it can act the same way.
74VEGA 466 C4 6.18@110,9.77@135.66 ON PUMP GAS
  #7
Old 01-23-2010, 06:18 PM
Smile 460 won't start
To all the responses and their editors might I just say "THANKS" for all your suggestions. I am lucky that I have an "old school" gas station/mechanic just a quarter mile away. Finally got it started, took it to him and he fiddled for a day and said "choke is not functioning". An adjustment later, it now starts.. Sort of red faced I am, but tomorrow is the real test. I need to start it, not the mechanic.. Again, thanks for all the suggestions, but I guess the simple truth is I screwed up the choke when I replaced the carb. Now we all know "the truth of the matter". P.S. He says I got a good truck. worktruck
Insurance
Date of Birth
Month Day Year
Privacy
